Possibly WTB C4 IFS/IRS
Old Sep 13, 2013 | 09:01 PM
56Transport's Avatar
56Transport
Default Possibly WTB C4 IFS/IRS
All set
Old Sep 13, 2013 | 09:35 PM
C409's Avatar
C409
..... I have a complete rotor to rotor Dana 44 set-up for sale out of a '95 Corvette ... its complete except for the shocks ... $1500 plus shipping ........ I'm in Clearwater , Florida near Tampa Bay ...........
Old Sep 13, 2013 | 10:06 PM
56Transport
What is difference in build years?
Don't know how pricing works but definitely will concider.
Thx!
Old Sep 14, 2013 | 04:04 AM
vetteoz's Avatar
vetteoz
84 - 87 had a slightly narrower hub to hub distance (18mm a side ) vs the '88+ cars .
Not usually a issue in a retro fit app with custom wheels
You can get a complete D36 (8" Ford equiv ) for $500 + but the rarer D44 ( 9" equiv ) only fitted behind the manual trans ( 20% of production ) commands prices typical of above
Old Sep 14, 2013 | 07:45 AM
56Transport
Not yet measured rim choice to rear fender well. 18mm hopefully is no decision maker.
Thx for that last part. AOD required. D36 it is.
Old Sep 14, 2013 | 08:08 AM
WVZR-1's Avatar
WVZR-1
There are many ways to use the Corvette C4 IRS components in the rear of any application. The primary components you need are the left and right drive components (hubs/bearings/caliper mounts etc.) and the differential component. The rear leaf is generally replaced with a coil-over in the conversions.
If you were interested I have all of the drive components needed and I've a 3.75 ratio D36 that's a new build never been run.
If you're a "polish" type of guy here's the rear components that are needed that have been "polished".
I have a set of control arms and spindles for the front IFS also. I would think that there's likely someone that does a cross-member for the F150 for the IFS. My front is '88+ and I'd think the preferred. The spindles with mine are '91+ and can use the lesser expensive GM front hubs for less expensive maintenance.
I believe I've got everything you need and if you wanted to do an axle ratio of less than 3.75 I've an empty housing that you could work with.
I've PM'd you an email address.
Old Sep 14, 2013 | 08:09 AM
C409's Avatar
C409
..... I can hook you up with a Dana 36 rotor to rotor also '95 for $500 plus shipping .................
Old Sep 14, 2013 | 08:14 AM
56Transport
I've seen your post somewhere & yes that is the plan.
PM me with detail plz!
Thx
Old Oct 8, 2013 | 08:04 PM
56Transport
IFS/IRS arrived.
Planning on tear down & polish.
Any recomendations on replacing worn out parts?
Thx!
Is this a Dana 44 ?? ?
Old Oct 8, 2013 | 08:42 PM
Y-ME's Avatar
Y-ME
IFS/IRS arrived.
Thx!
That is a Dana 44. Basically if you paid over 1G for the rear it's a D44 and if you paid 600 or less its a D36.
Old Oct 9, 2013 | 12:07 AM
Y-ME's Avatar
Y-ME
The Dana 36 had an extra bolt in the top middle of the diff cover (bat wing) also the batwing had different shaped holes in the structure.
What year did it come out of and what trans did it have?
Old Oct 9, 2013 | 10:32 AM
WVZR-1's Avatar
WVZR-1
It's an early model D44 and some say it's the preferred housing to use for builds, others don't have preferences. Does it matter? In your application I'd say NOT!
The early rear suspension and brake package is "shoe in rotor" for an e-brake and parts for the e-brake are more difficult to source. Your parts appear very clean including the shields for the rear e-brake etc.
Your front is early also and I believe you mentioned that is what you wanted so it appears you've done well. Your rear is likely a 3.07 unless it's been tampered with.
Are their ABS sensors attached to the front spindles with a single fastener or are there provisions for ABS? Are there ABS sensors on the rear knuckles? Again these would be attached with a single fastener.
Things that can be verified for you:
1. There will be codes stamped into the springs front and rear. If you check those it's possible to ID the suspension rates for the assemblies if you intend to stay with the "transverse leaf"!
2. On the end cap of the steering rack there will be a 2 letter code on it. Since it's an early unit that could be likely ID'd from that code.
For a FSM an '87 would be the most recent and would cover it all including ABS if it has it. You won't be using BUT when you disassemble the parts ID the position the sensors were removed from. Someone will need them.
Who will be doing the polishing? You or an outside vendor?
Old Oct 9, 2013 | 05:54 PM
56Transport
I'd say you are correct there sir. Just glad it was caught before Flatout kit was ordered.
We were all sweating opening the crate then seeing shiny parts showing thru.
Will be breaking into that hopefully this month if polishing goes as planned.
Did not see ABS sensors & that is why '84/'85 was chosen so there were no extra holes in parts.
Have not looked into transverse leaf options. Did notice rear leaf had what appeared wood sliver shims added.
Something most likely is past its expectation date. What is needed & ideal for this build is in question.
Never did find code on rack. Then again did not look close because my thought was rebuild/replace for undetermined steering column.
Could not find willing party to polish so my garage will now be polishing workshop 101. I see many long nights & weekends ahead of me.
Thank you all.. .
Unanswered questions:
- service manual
- replacing worn parts
- Daily driver 3.07 gear ratio?
- F/R transverse leaf options
Old Oct 9, 2013 | 06:09 PM
WVZR-1's Avatar
WVZR-1
Thank you all.. .
- service manual
I addressed the service manual, explained how to ID the springs and the rack and mentioned it was likely the 3.07. How heavy is the truck?
The question asking that you ID the transmission was/is irrelevant.
I asked who was going to do the polishing. That might have something to do with the parts list. I have a parts list that I'd probably consider. You could I guess have the "long list" and modify it as needed BUT the first thing that needs to happen is the cover removed from the differential to confirm the condition of the ring and pinion. If it's sat for many years with no rotation the condition of them could be of maybe some concern.
What are the ratios of your AOD? I believe you mentioned that for the transmission and I don't recall you ever mentioning to me which engine. Which is it?
Old Oct 9, 2013 | 06:13 PM
WVZR-1's Avatar
WVZR-1
Thank you all.. .
- service manual
Damn - I just now noticed your responses in the "quoted text"!! I'll check them further.
There will be a code on the end-cap plug on the rack/pinion. As clean as your parts are I wouldn't do anything at all with the rack other than replace the o-ring seals on the left - right lines at the spool valve. Nothing else unless maybe the tie rod boots were bad. Outer tie rods are a "maybe".
I couldn't see the e-brake cables but if the slugs are secure on the ends and there's no cables frayed I'd soak them in ATF/acetone mix (50/50) for a while and after disassembling the calipers and rotors inspect the e-brake hardware. Maybe because it's a fresh build buy new shoes or get yours relined. Hold-down hardware? Clean well and reuse. Hubs? I'd maybe just check them well while everything is apart and maybe reuse. If they're low-mile OE they may be better than what's on the shelves these days. You need two washers so that when you reassemble the knuckles all will be well.
A bearing and seal kit for the D44 (6 bearings, 3 seals, pinion nut and shims for a refresh of it. Depending on the condition of the bushings in the cover I'd maybe leave them alone OR depending on how the D44 will be mounted in the frame you may need to narrow it or just whack the ends of it to "condense it". There's many ways to mount the D44.
You should still have my email I think - drop me an email and I'll cover a parts list for you!
Old Oct 9, 2013 | 06:15 PM
56Transport
Now that suspension is in house if anyone may be interested this doner is for a '56 Ford F100 Panel build that has been meaning to be done. If it doesn't I will not bore with the rest of the build.
Old Oct 9, 2013 | 06:28 PM
56Transport
My guess in neighborhood of 3500lbs
IThe question asking that you ID the transmission was/is irrelevant.
Now on my 2do punch list
IWhat are the ratios of your AOD? I believe you mentioned that for the transmission and I don't recall you ever mentioning to me which engine. Which is it?
Tyranny is out of '87? Ford Turbo coupe from what I recall. Been about 6yrs since brought it home & still need to figure if it's ideal right now with 302.
Many Thx .. .
- service manual
To Possibly WTB C4 IFS/IRS
Old Oct 9, 2013 | 06:40 PM
WVZR-1's Avatar
WVZR-1
- service manual
What hasn't been addressed?
Old Oct 9, 2013 | 07:03 PM
56Transport
?service manual:
Is there specific service manual for this suspension to help break down & ordering replacement parts.
?replacing worn parts:
Most likely answers itself in last question but also where is the correct place to order worn out parts.
?Daily driver 3.07 gear ratio:
I don't know gearing ratio's yet. What is ideal gear ratio for daily driver truck.
? F/R transverse leaf options:
You mentioned if I were to keep transverse leafs. If keeping what do I replace them with. If removing any option recommendations.
Many Thx !
Old Oct 9, 2013 | 07:24 PM
WVZR-1's Avatar
WVZR-1
?service manual:
Many Thx !
Any FSM '85 - '87 the '87 would be the most complete.
The parts until you generate a list is useless. There's NOT a single source! I don't recall where you're located. That could be relevant.
3600# truck with what tire/wheel combination, the engine (you hinted 302), transmission drive ratios. If you need a ratio higher numerically than the 3.07 you might be better off selling the 3.07 you have and buy a later 3.45 for a couple reasons. The later I believe is a casting that would polish easier and refreshing the 3.45 would cost the same. A 3.07 ratio D44 should sell easily. If you wanted to do gears for your D44 you've got easily available 3.73 and 3.91 - the 3.54 gear set is a hard find. I have an NOS GM 3.54 gear set.
The rear spring can be "softened" considerably but the front being early not as easy. Coil-overs are possible but your choice of the early front means there's considerable modification needed to the cross-member that's not as easy. If the fabricator knew going in and coil-overs were desired it could be done in a single modification. It needs decided before you get very far.
