Another PKE Thread
Old Sep 22, 2013 | 03:56 PM
Rob93LT1's Avatar
Rob93LT1
1st Gear
Default Another PKE Thread
I have a 1993 LT1 that I bought a few years ago. When I bought it, the PKE system didn't work (still doesn't). I turn it on and the PKE light comes on and stays on. It does this until I take the key out and put it in again. I checked the 3 PKE fuses and they're all good. I also don't know if my transmitter is programmed because the system doesn't work. I also cannot get it into programming mode. I hit trip odo twice and hold fuel info and the light doesnt blink. Any ideas?
Old Sep 23, 2013 | 07:43 AM
markKlein's Avatar
markKlein
Most likely the receiver unit is bad and neesd to be replaced. But what exactly do you mean by "I turn it on"? You turn the PKE system on? How?
Old Sep 23, 2013 | 09:51 PM
mlbfreaks2765's Avatar
mlbfreaks2765
1st Gear
No I meant I turn the ignition to on. (I'm Rob93LT1. Corvette forum will not let me sign in on my account)
Old Nov 25, 2013 | 07:15 AM
jad9943's Avatar
jad9943
Has anyone found the correction to this problem? I have the same thing! Exactly!
Old Nov 25, 2013 | 08:32 AM
Hawg55's Avatar
Hawg55
The PKE does turn off and on by holding the button down. I have a convertible so it only has one button. If I hold it down until the locks cycle it will turn off. Do the same thing and it turn back on.
Old Nov 25, 2013 | 01:56 PM
2HIP4U's Avatar
2HIP4U
If I recall correctly:
1. Put your ignition key in the ignition. (BUT DON'T TURN IT TO THE ON POSITION.)
2. Hold down the "door" button on the key fob. (It has to be longer than a few seconds)
3. You should hear the locks cycling. (They will turn on and off) One setting is to unlock only the driver's door, the other is to unlock both doors.
4. Let up on the key fob button when you reach whichever setting you prefer.
Old Jun 30, 2014 | 07:10 PM
SpidArman's Avatar
SpidArman
Default Did you ever figure out your problem....
My 93 coupe just started doing the same thing... The PKE system was working great until Friday night.
To Another PKE Thread
