I buy at one place NO ETHANOL.. But, I also haul fuel, So I know where to buy and not be worried that some driver dumped wrong crap in tank and didn't tell someone.
Some of us live in states that don't give us the option of buying non-ethanol gas. I think the OP was looking for our various means of dealing with ethanol in gas, vs. the recommendation to not buy gas with alcohol in it.
I use Stabil Marine in every single internal combustion engine I own. Zero issues.
Your car won't run on E85 unless it has been extensively modified.
We don't have any non-ethanol gasoline in California. Haven't for years. At least none that is available at "normal" gas stations...
This isn't necessarily true. Your car "will" run/burn E85, it will just freak out, if left stock. Because the oxygen sensor (among other issues) won't recognize the mixture and toss a "check engine" light. "If" the stock engine is tuned for E85, you can actually expect to see a marginal improvement in performance (this would need larger injectors, and supporting mods)
The stock FUEL LINES won't support ethanol. It's not just a problem with the stock injectors. The ethanol will gradually dissolve the soft lines (and stock pump). The stock valve seats will also be effected from the ethanol in the long term.
E10, E15 is a mixture that rides on the "limits" of these older cars. Modern/new cars are already designed to support E15.
If a fuel additive is used to resolve the issue how frequently is it added ie each tank, certain miles driven, or duration of time? Thank you for your replies.
10% ethanol is in pretty much all of the gasoline sold in the Pacific Northwest. Non-ethanol gas is available but it's a PITA to find. It will usually be at those stations where you need to open a pre-paid account or have a commercial account. We've had the 10% stuff for at least a good 5 years and I have not seen any sort of issues in any of my vehicles.
Small engines can be another story. I have a Briggs & Stratton powered lawn mower that doesn't run very well on the 10% stuff so I add just a bit of octane booster. I have a Toro weed-eater that runs just fine (needs a 50:1 oil mix). My 8000 watt Briggs& Stratton generator runs fine on 10% ethanol 87 octane gas.
Corn gas is here to stay. If your car is a DD you can get away with it. I found the best additive to combat the ethenol in ANY gas engine that is going to sit a while is Star-Tron. The problem has always been worse in our marine engines. They sell 2 different concentrations, read the lable 1 or 2 ounces to x amont of gallons of gas. Wally world sells it in the marine section. Its just a matter of time before the tree huggers get there way and they add more corn to our gas. Dave
Octane isn't the issue, it's the alcohol burning drier and hotter. You need something like stabil or seafoam to help add some lubricity to the mixture. I ALWAYS use the highest octane fuel possible for small engines, and add marine stabil. No issues.
I have mine tuned for e85 only changes are 60lb injectors and a new 255 pump. Here is a dyno sheet from the tuner.
I recently switched back to the 93 pump gas tune, but the car seems to run better on e85.
FWIW a lot of misinformation out there. One being the motor runs hotter on e85. This is not true. They actually run cooler. Go to any dragstrip and talk to the people there. That is one of the big advantages in running alcohol. The motor stays much cooler.
In Iowa we have had the blended fuels for many years and like mentioned above we have had zero issues with any fuel system components. As long as you don't let fuel sit in the small engines over the winter or summer they won't know the difference.
Wrong. Very wrong. There is a chemistryproblem with older models where fuel system components are not design for the higher ethanol concentration.
Are you basing this on any actual experience or just what you have read? I don't mean this in a bad way, just asking.
I see people posting about using additives to offset the use of ethanol in fuel with zero problems. Well would they have had problems without the additives? My experience has been zero problems with 10% for years and even 85% for 6 months. Maybe in time I will have a fuel line problem, but then again is it because of the ethanol or the lines being 20+ years old? Who knows?
My biggest beef is that ethanol is less "green" than petroleum, burns our injectors and pumps, and benefits only the farmer and farm lobby. The rest of us and the environment pay the price for a failed science experiment that is allowed to continue.
I been using Star-Tron in some of my vehicles. I usually add a little each time i fill up. Not sure it really does anything, but cheap insurance. I havent noticed any issues with my autos, but i have had problems with some of my small engines. those get treated fuel, namely the Stabil Marine grade formula. Not real cheap, but it goes a long way.
Mike
