Hydro lock
Old Oct 8, 2013 | 01:21 PM
BGFIREFIGHTER's Avatar
BGFIREFIGHTER
4th Gear
Default Hydro lock
My engine hydro locked. I was not driving it. I went to start it in garage and it would not turn over. I found out the fuel diaphram ruptured and gas got into the engine. I need to change the oil and filter, new spark plugs, new fuel diaphram, and dry out inside of engine. Any idea of the cost to have these items repaired ?
Old Oct 8, 2013 | 01:33 PM
ch@0s's Avatar
ch@0s
This is something you can do yourself. Change what you mentioned and change the oil a couple of times.
Old Oct 8, 2013 | 03:40 PM
Kevova's Avatar
Kevova
Cost by pros 500.00 ish. Towing, tune up (spark plugs), FPR replacement, lof ... shop may try to sell you flush. and there will always be something more. Only 1 cylinder is locked usually but fluid will be in others. Most of the process would be routine maintaince. Other than dissabling ignition (unplug ICM) and injection (pull fuses for injectors) so engine could be turned over to clear cylinders. You would want a fire extinguisher and water hose close also car outside and away from anything you care for, there is a slight chance of flash fire.
Old Oct 8, 2013 | 04:10 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
A lot less if you do it yourself. Make sure its just gas and not water from a head gasket.
Old Oct 12, 2013 | 10:14 AM
Paul Workman's Avatar
Paul Workman
Yeeeaaaah... Unless the ignition switch was turned on (engine off) for an extended period, AND an injector just happened to be also stuck open, AND the intake valve was open...I'm leaning toward coolant/ head gasket issue, myself.
To the OP:
If you pull the plugs and crank it (taking precautions against fire hazard), you'll know PDQ if it is coolant or fuel that is locking it. Then you can proceed according to what squirts out of the plug holes.
Either way, an oil/filter change is SOP, and a new FPR is a given. But, as for plugs or other stuff...nah.
Whether water or gas is determined to be locking it, bringing the piston to the top and injecting compressed air in the spark plug hole will clear it out. Then rotate the crank 180 degrees, and squirt a little motor oil in the cylinder and roll the starter a few revolutions. OR, you can crank it with all the plugs out...will work, but might take longer.
If it is water, you'll have to find out where it got in. The cost will be for gaskets, and your time if you're a DIY guy. No biggie.
If it is fuel, you may luck out, cost wise - tho I'm still of fuel locking it, tho the FPR replacement is a given. Change oil/filter and the regulator, lube the cylinder(s) (optional) and that should do it.
Note: The only time I saw a fuel caused hydra-lock was after the ignition switch was left on for a minute or so and an injector was stuck. It didn't take long to fill the intake runner!
Old Aug 31, 2019 | 06:48 PM
Garibaldi500's Avatar
Garibaldi500
Here is rhe lamp test video
Checking the injector #7 control signal
Old Aug 31, 2019 | 07:58 PM
383vett's Avatar
383vett
https://youtu.be/oHMAOjqjtaI
I guess 6 years later we’re dealing with C5s.
Old Aug 31, 2019 | 08:20 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Total cost to repair is $148.00. The cost of one pizza, a case of beerr, two oil changes and a new fuel diagram.
Replace the fuel diaphragm. Pull the plugs, drain the gas, clean the plugs and replace. Change the oil run for no more than 10 minutes, then change the oil and filter again.
Now you are good.
The beer and pizza is for your friends who help you out.
To Hydro lock
