Rear end movement when accelerating - 1992
What should I look for and how can I terst to see what is causing this!
Other than that the acceration and everything is great with the car, no hesitation only the slight slip feeling at the split second you take your foot off the gas pedal or when you put you your foot on the gas pedal to begin to re-accelerate.
No slip or movement when starting off from a dead stop!
Thanks for any advice..
The rubber bushings for the rear (trailing links etc) should be checked too.
BTW when was your last four wheel alignment?
OP: My money is on the C-beam joint(s) slipping, especially if you notice the holes in the aluminum are oval instead of round. This is usually accompanied with a ridge of aluminum on the C-beam around the edges of the steel washers - a dead giveaway the joint is not secure.
Bill Boudreau has some pretty nifty C-beam plates that address the squirming at the joints - the differential joint, especially - not to mention making dis-assembly/reassembly so much easier they are worth the cost if they did nothing else, IMO
I know I have a little sqeek from time to time on the rear passangers side and I did spray W-D 40 on the U-joints and it seemed to help with the sqeek but does come back once in awhile, how will I tell if the U-joints are bad?
Thanks so far!
Thanks so far!
As mentioned, there are other bushings; e.g., the bat wings and control arms, dog-bones, etc. at play as well.
Well, I've never heard of WD-40 being used to detect a u-joint issue. Due to the cup seal, I question if it would be possible to get much WD enough to make a difference in there. But, for the sake of argument, if WD does quiet a u-joint, I'd take it as a sign to replace the joint(s) immediately.
Far as testing u-joints, if there is any rotational or lateral "slop" in a universal joint, it is a dead giveaway that it needs to be replaced. You might have to pry on the joint to see if there is any lateral play, and twist the shaft back and forth to attempt to discover any play.
And, usually there is a poping or ticking noise at low rpm too. By the time you start feeling vibration that increases with drive train speed, it is a pretty good chance at least one of the u-joints in the drive shaft is bad.
Another source of a popping or ticking noise, especially when shifting from a forward to reverse or visa versa is the bearings in the wheel hub.
There are a total of 6 u-joints in the C4 IRS. Spicer is the manufacture recommended for the ZR-1 as well as the Vipers, far as u-joints go. You want the ones that do not have a grease fitting, as that fitting tends to weaken the joint.
I'd try checking and re-torquing the bolts on the C-beam first, and then move on from there in a methodical approach.
Called Killebrew. Measured and videoed every last link and bushing.
What was the changer? Rear toe setting. With as close to zero thrust angle as possible.
Make sure the dog bone bushings are solid. The toe rod ends are tight.
Have the alignment guy not compensate for the road crown.
Add just a bit of toe in to keep the rear end tracking straight. 0.10 degree is good.
This is not a common problem yet those that have experienced it have yet to discover it's resolution.
PM me if you'd like I can go into greater detail.
Thanks so far!
I highly recommend you choose wisely the locations where you spray wd-40. Most of the time it just attracts dirt and LEADS to a failure.
