Sensor on block
Old Nov 6, 2013 | 08:46 AM
SoAlVette's Avatar
SoAlVette
Default Sensor on block
What is the sending unit or sensor on the passenger side block rear by the starter. I have gone thru my FSM and cannot seem to find what it is. It has a metal protection shield over it that connects to the oil pan bolts. Looks like I may have an oil leak there. Oil pressure sending unit maybe?
Old Nov 6, 2013 | 08:54 AM
c4cruiser's Avatar
c4cruiser
That would be a knock sensor. But that sensor is threaded into a coolant passage so there won't (shouldn't) be any oil leakage. Maybe oil is dripping down from a leaky valve cover gasket.
Old Nov 6, 2013 | 08:55 AM
IndyTim's Avatar
IndyTim
On an LT1, I would say you are referring to the knock sensor. May want to post your year.
Old Nov 6, 2013 | 09:08 AM
SoAlVette's Avatar
SoAlVette
95 LT1, I though the knock sensor was on the driver side. Are there 2 of them? FSM only showed the one on the driver side. FSM can be difficult to navigate, to say the least.
Old Nov 6, 2013 | 09:30 AM
aminnich's Avatar
aminnich
Yes, there are two of them. One on each side.
Old Nov 6, 2013 | 09:31 AM
SoAlVette's Avatar
SoAlVette
Well, that makes sense, I will look closer at the valve cover gasket as the culprit. Thanks all.
To Sensor on block
