air cleaner
Old Nov 7, 2013 | 06:15 AM
nicpete's Avatar
nicpete
Default air cleaner
just a question,is there really a big difference between a stock AC Delco
air cleaner and a K&N filter?
thanks in advance
Old Nov 7, 2013 | 07:25 AM
NuckinFutz93's Avatar
NuckinFutz93
The oil from the K&N will dirty up your MAF sensor wires. You'll need to keep and eye that and make sure to keep them clean.
Old Nov 7, 2013 | 08:30 AM
JackDidley's Avatar
JackDidley
I doubt the K&N will get you any power. It can be cheaper though. mine has 150,000 miles on it.
Old Nov 7, 2013 | 08:47 AM
94z07fx3's Avatar
94z07fx3
IMHO, if you're going to run the K&N, save your old paper filter and run it for a week after you clean and oil the K&N while it dies out a bit.
Old Nov 7, 2013 | 08:50 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
No.
Old Nov 7, 2013 | 10:45 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
From all the study's I have seen a good clean paper filter will flow the same as a K&N.
Old Nov 8, 2013 | 05:30 AM
nicpete's Avatar
nicpete
thanks everyone i appreciate the info
Old Nov 9, 2013 | 07:31 AM
WW7's Avatar
WW7
A few years ago I remember reading a test result where the K+N and paper filters flow about the same when new , but as the paper gets dirty it loses some of it's flow, while the K+N retains almost full flow when getting dirty...WW
Old Nov 11, 2013 | 06:03 AM
tilac999's Avatar
tilac999
I'm returning my car to stock and selling the K&N filter if anyone wants it. Like new.
Old Nov 11, 2013 | 08:08 AM
WW7's Avatar
WW7
To be honest the only negative I have heard about the K+N filters is that they can foul your MAF sensors.. This is not the fault of the filter, but happens because to much oil is sprayed on the filter and is then blown onto the MAF sensor.. This is one of those times when less is better, you just want to mist the filter, not saturate it...Im sure these filters work because many on here use them.. It's just easier for me to buy a Puralator air filter and put it in...I also have a brand new K+N filter that came on my 89 when I bought it sitting in a box in the garage.......WW
To air cleaner
