L98s
Old Jul 8, 2002 | 12:30 PM
Electron2002's Avatar
Electron2002
Default L98s
Do L98s require premium gas? Have any bazaar quirks? blah blah blah...
I'm thinking about a 89-91 with a 6 speed. Anyone have any warnings, suggstions, or the like.
[Modified by Electron2002, 10:31 AM 7/8/2002]
Old Jul 8, 2002 | 12:44 PM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Default Re: L98s (Electron2002)
Premium gas only for my 90. I am fairly sure that the owners manual confirms this.
Old Jul 8, 2002 | 12:52 PM
rcolling's Avatar
rcolling
I used the middle grade, 89 for mine and never had a problem. Ran it on the dyno with that gas and it pulled just fine.
One of the most reliable, trouble free engines you can find :yesnod:
Old Jul 8, 2002 | 12:54 PM
markmaz's Avatar
markmaz
my l-98 (1986) is just happy to have the attention , but occasional low octane does not seem to hurt it .
Old Jul 8, 2002 | 12:56 PM
needanother1's Avatar
needanother1
Default Re: L98s (joecaver)
Owners manual recommends premium fuel, but says other grades may be used, with "some loss of acceleration performance".
Aside from the TPI system, and maybe the aluminum heads and roller cams on the later models, the L98 is just basic old small block Chevy.
Old Jul 8, 2002 | 01:09 PM
SpedRacr93's Avatar
SpedRacr93
90-91 L98s will need premium due to 10.25:1 compression.
89 can run on regular with lower compression and aluminum heads.
I only run premium in my 89 though.
Technically, you can try the middle and lower grade fuels in either. You just need to be aware of detonation. The timing retards on these cars work well enough that you might not even notice it without directly monitoring it.
Old Jul 8, 2002 | 01:10 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
I couldn't be happier with mine. It runs better than I expected and gets 24 mpg highway. It is one great cruising motor. No shakes, no hesitations, no weak spots. And--you can power-wash the motor without fear. Is it the fastest thing out there? Not likely. I think it combines the best of both worlds--plebnty of horsepower with long-term reliability....no regrets!
Old Jul 8, 2002 | 01:14 PM
dgoodhue's Avatar
dgoodhue
I only run 94. Has anyone look at a scan tool (daicom, DM, etc.) to see if the car is pulling out any timing with lower octane?
Old Jul 8, 2002 | 01:19 PM
chucks88's Avatar
chucks88
Default Re: L98s (dgoodhue)
89 octane for my"88
Old Jul 8, 2002 | 01:26 PM
vader86's Avatar
vader86
Default Re: L98s (chucks88)
mine has the iron heads, i use regular
i noticed no loss in performance or anything
Old Jul 8, 2002 | 01:42 PM
Jim85IROC's Avatar
Jim85IROC
It'll always be pulling out timing, even with 94. With 87 in my GTA, I had 27 knock counts in the first 2 miles of driving, and I was driving it easy. Taking off easily from stop lights it was pulling out 2-4* of timing. Going up a hill, it was pulling out up to 13* of timing. I haven't hooked the scan tool up with the premium gas, but it'll still be getting knock counts unless your timing is too far retarded.
Old Jul 9, 2002 | 09:17 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I run premium in my 88, it seems to like it just fine. I could probably run mid-grade without any problems.
Qirks - The area between the radiator and AC condenser is a vaccum bag. It will pile up with leaves
Old Jul 9, 2002 | 02:28 PM
90qzrblu's Avatar
90qzrblu
Default Re: L98s (jaa1988)
When I run 87 octane in my 90, i get a little knock, so I stick to the 92 octane...
Old Jul 9, 2002 | 02:42 PM
scorp508's Avatar
scorp508
The earlier lower compression can run 87 octane. You might not get full potential, but if you are just cruising 3000 miles across the country why not save some money.
I run 94 in my '87 even though it is completely unnecessary. But in the same breath I can run some more timing BTDC and get no knocking.
Old Jul 9, 2002 | 11:53 PM
Vettman 1's Avatar
Vettman 1
I've always used premium as the book suggests, the cost difference in Ca. is only a buck or so per tank between lower octane and premium. I have 136K miles on the clock, and use no oil whatsoever, and I just got 29 mpg on a trip to Utah. :hat
Old Jul 10, 2002 | 12:49 AM
dppeaden's Avatar
dppeaden
I use 93 oct only. When I was test driving it I put 89 oct and you can tell a difference. doesn't ping but it's a snail.
Old Jul 10, 2002 | 01:06 AM
Vette9d1's Avatar
Vette9d1
Default Re: L98s (dppeaden)
On my '91 I do notice a difference between the premium and the middle grade. Its worth ten cents or so extra! :yesnod:
To L98s
Old Jul 10, 2002 | 06:16 AM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Nothing but Amoco White Premium 93 octane goes in my babies. :cheers:
Old Jul 10, 2002 | 11:29 AM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
Someone's gotta be a serious moron to put anything less than premium or "supreme" grade fuel in their L98. That would be listed in my book under "abuse". If someone with even the least bit of intelligence about L98s put less than premium grade in their vette, they obviously are with the intent on sabotage or just plain destruction to their ride. I put nothing less than "supreme" in mine which is always atleast 92 or 93 Octane. If it was available closer and more often where I live...I would put even higher grades in as much as possible. :cool:
Old Jul 10, 2002 | 11:36 AM
scorp508's Avatar
scorp508
Default Re: L98s (MaSTeRofDZaSTeR)
:rolleyes: :rolleyes:
Any real reason why? They run fine on less.
