power steering problem
Old Nov 24, 2013 | 12:56 PM
Tom Slick 88's Avatar
Tom Slick 88
Default power steering problem
88 vett power steering comes and goes. Pump is not making noise belt needs to be changed. Feels more like a gear box than thew pump. What should I check.
Tom Slick 88
Old Dec 1, 2013 | 10:46 AM
cfwp.n41's Avatar
cfwp.n41
Take a turkey baster and pull out 3/4 of the fluid from the reservoir and replace it with Lucas Power Steering Fluid w/ Cleaning agent...try it every other week for a month. Is your fluid gray-ish?
Old Dec 1, 2013 | 12:29 PM
c4cruiser's Avatar
c4cruiser
If the belt is slipping (especially when turning the steering wheel) then I would suggest replacing the belt and make sure that the belt tensioner is good. A weak tensioner will cause belt slippage.
If the fluid is old and dirty, it's probably time to flush all of it out and refill with a good PS fluid. I have had excellent results using Red Line synthetic PS fluid in my '87. The pump is original to the car and I see lots of high RPM usage at autocross and track day events.
A few years ago after some track events, the pump would whine loudly once the fluid got hot. I added a power steering fluid cooler and the Red Line fluid. It's quiet and everything works fine.
It's far easier and cheaper to try a new belt and fluid change before you go replacing the rack.
Old Dec 1, 2013 | 03:26 PM
Klondike's Avatar
Klondike
Had that problem too. At low rpm in a parking lot or rounding a corner after stopping, the thing was nearly unsteerable! Several times when rounding a sharp corner the power assist would suddenly go away and leave me to wrestle the car around the corner. I thought I'd break the steering wheel off the shaft a couple of times. Couldn't figure out if it was the pump or the rack, so I went all the way and did both! Put in a quicker 'sport rack' from Zip. Was not as hard or expensive as you might think and now the car is a blast to drive.
Old Dec 3, 2013 | 10:30 PM
Tom Slick 88
Thanks guys! I know the fluid is full but I don't know if it is dirty, I will start there and work my way up the money tree. Gotta love em!!
To power steering problem
