Flat spotting ?
Old Dec 4, 2013 | 11:43 PM
Patsgarage's Avatar
Patsgarage
Default Flat spotting ?
Just drove the wifes 89 Vert to work tonight. The car had sat for maybe 10 days outside under a cover on asphalt. For the first 2 miles or so there was a pretty bad vibration, almost like an out of balance wheel. After a few miles at 50-60mph it went away, so I am guessing the tires did not like sitting in one spot. The tires are only a couple of years old with less then 10k on them. I can not think of anything else that would cause the vibration, so I guess I just have to drive it more. Can anyone give me any other ideas as to what would cause this ?
Old Dec 4, 2013 | 11:55 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Some tires are more prone to that problem than others. The old bias ply nylons were famous for it. You may try to make sure the pressure is correct, maybe up to 35psi. low tires tend to do it worse. I think its a combination of things, stiff tires and suspension that may or not be close to or out of tolerance.
Old Dec 5, 2013 | 12:03 AM
Patsgarage's Avatar
Patsgarage
So true about the old tires ! I pulled a Cadillac out of storage after 20 years and the tires were so bad that they stayed flat on the bottom even off the rims. The suspension is in good shape, alignment is spot on, maybe I will try to put a little more air in the tires and see if it helps.
Old Dec 5, 2013 | 02:09 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
The tires may only be a couple of years old, but what is the date code on them.. Some dealers may have tires in stock that are more than a few years old..
Old Dec 5, 2013 | 02:58 AM
NJLS708's Avatar
NJLS708
Definitely try putting more air in the tires if the car is going to sit. If you have proper inflation 10 days is not long enough to cause a flat spot.
Old Dec 5, 2013 | 07:38 AM
WW7's Avatar
WW7
I was having the same problem with my tires getting a flat spot in the winter when I don't drive it as much...The solution is to get some old carpet , fold it over double and run your car up onto the carpet when you put it away......This was suggested to me by a friend and it has worked great for quite a few years....Give it a try........WW
Old Dec 5, 2013 | 08:55 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I had a car a few years ago that would flat spot bad. Even just overnight it would do it. It would also recover in just a couple miles.
Higher air pressure helped it some but not completely.
For winter storage, I picked up a junk set of rims with junk tires. Who cares if they flat spot. Even with the bad set on, it still lets me move it around if I need or want to.
Good luck.
Old Dec 5, 2013 | 09:53 AM
dtana's Avatar
dtana
Wow, what type of winters are you guys dealing with?
5 years ago when I totally busted my left ankle & had it operated on, my stick shift 300ZX sat outside on asphalt from mid Jan to early April. Of course this was Nor Calif but the temps ranged from low 30s to low 70's. In that entire time I had a buddy come over & drive the car twice. No flatspots, no special preparation on the car. The battery even held up. The car & tires were fine after all that.
Old Dec 5, 2013 | 05:54 PM
motor city dave's Avatar
motor city dave
St. Jude Donor '16
....Same here.
Old Dec 5, 2013 | 07:14 PM
gerardvg's Avatar
gerardvg
If you are storing a car over winter around 40 psi is good, the lower the pressure the more tires conform to the shape of the concrete or tarmac it sits on. So you will have tires slightly out of round, i have had no issues with 38/40 psi tire pressure. I had the car of the road over six months, with no vibration when back on the road.
the best thing would be to raise your wheels of the ground and support the wishbones and rear lower control arms with even size blocks of wood, so the suspension is still holding the car up.
Otherwise you may have to wait a few days for the suspension height to settle if the springs have had no tension on them for six months or more.
All things to consider for those of you that put your vette's in hibernation over winter.
To Flat spotting ?
