ecm not responding
Old Dec 18, 2013 | 11:59 PM
84VetteMan205hp's Avatar
84VetteMan205hp
Default ecm not responding
title says it all my ecm on my 84 vette will not respond to any code reader and also it will not trigger the check engine light, ill unplug things that i know will trigger the check engine light and it wont. i did the paperclip test and it just gives me code 13 or 12 the whole time and tps was already changed a year ago
Old Dec 19, 2013 | 12:48 AM
DanielRicany's Avatar
DanielRicany
Run the engine and unplug the EST wire, then check your check engine light again, see if it comes on.
Old Dec 19, 2013 | 05:29 PM
Kevova's Avatar
Kevova
If you don't have FSM you need to get access to one. There should be a chart related to scanner. Take a voltmeter and connect it to terminals you use to make like flash there should be voltage present. If you have voltmeter with min/max function use that setting voltage should be be 1-4 volts if not if maybe why scanner wont work.
To ecm not responding
