heater control problems.
Old Dec 23, 2013 | 12:35 AM
carrmann's Avatar
carrmann
Default heater control problems.
my heater controls were getting old and had a hard time switching between selections . then completely quit working, cannot make any selections light up or show any sign of working at all. but do light up when headlights are on but still are non functioning.
replaced with tested (supposedly good one) from ebay and still no sign of working at all.
not sure where to look next, i am looking for any advice or known fixes.
please let me know if you have any advice.
Old Dec 23, 2013 | 01:03 AM
GKK's Avatar
GKK
Need the year of your Vette?...
Old Dec 23, 2013 | 08:36 AM
Kevova's Avatar
Kevova
Check power and ground at control head. Illumination with lights on different circuit. C60 manual or C68 automatic?
Old Dec 23, 2013 | 11:47 PM
carrmann's Avatar
carrmann
Originally Posted by gkk
need the year of your vette?...
1986
Old Dec 23, 2013 | 11:50 PM
carrmann's Avatar
carrmann
C68 automatic ,push buttons on heater control face.
no manual heater controls ( no slider or turn **** for fan ).
Old Dec 24, 2013 | 01:21 AM
Cliff Harris's Avatar
Cliff Harris
Check your "A/C" fuse. It supplies power to the control head when the ignition is on.
The "CTSY/CLK" fuse is also involved. It supplies power to the control head all the time to maintain the settings. It also supplies power to a lot of other things, so you'd probably know if it is blown.
Old Dec 24, 2013 | 08:13 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Test the 10 amp gages fuse, may be blown.
Old Dec 24, 2013 | 04:30 PM
Cliff Harris
I checked the FSM and found that the "A/C" fuse if for the compressor, so I was wrong on that.
Agent 86 rocks again.
Old Dec 26, 2013 | 06:18 AM
carrmann's Avatar
carrmann
ive gone through the fuse box and have no blown fuses.
i will check for power at the control head tomorrow on my day off.
Old Dec 26, 2013 | 06:21 AM
carrmann's Avatar
carrmann
do you know which wire or wires should have power at the control head.
Old Dec 27, 2013 | 02:18 AM
Cliff Harris
Since my HVAC system is only partially working right now, I just happen to have the FSM open to the C68 section…
The GAGES fuse supplies power on a pink/black wire to pin C2 (ignition on).
The CTSY/CLK fuse supplies power on a pink/white wire to pin D4 (all the time).
The DEFOGGER circuit breaker supplies power on a black wire to pin C15 (all the time).
Old Dec 28, 2013 | 01:43 AM
carrmann's Avatar
carrmann
Thank you for your help in identifying these wires for me.
i was able to track down the problem and get my heater working again.
To heater control problems.
