engine problems, help please
Old Jan 11, 2014 | 01:36 AM
Lord.Baal's Avatar
Lord.Baal
Default engine problems, help please
Hey,
so my car has had some knocking issues in the past, 93 LT1 engine
and now all the sudden when i get to about 55 mph it starts to really knock and like cut out. i talked to another c4 guy in the area and he thinks its not getting enough fuel and a fuel line or pump problem.
basically it runs fine and accelerates fine up until about 55mph and then when i accelerate, and the harder i try, the worse it gets to the point of the pedal kicking back at me (not caused by asr, turned asr off)
and i am really worried about the engine.
any thoughts? i just had the dealer service the rear differential and power steering and they didnt notice anything in there inspection.
anyone know a good place to go, or just go to the dealer in town? (santa rosa)
it there anyway to diagnose this problem??
help please!!!!
thank you!!!
just to add, it starts by knocking a bit, then more, then it feels like the engine is cutting out and i slow down and that is when the pedal comes back at me. the more i pushed it the worse it got so now i dont push it past 2k rpm
Old Jan 11, 2014 | 03:01 AM
DanielRicany's Avatar
DanielRicany
Okay well try getting the highest octane gas that you have available to you, and see if it still knocks, use up all the old gas first though. If it still knocks buy a bottle of octane booster and put it in the tank and drive it. If it goes away then you are dealing with a spark knock issue, which is more of a relief. If it still knocks then you are probably dealing with a mechanical engine knock.
Remember, if it is spark knock, this can be deadly. Spark knock is like taking a hammer and hitting your piston full force. It can destroy your engine in a matter of seconds, so not good to try to reproduce it while it is still a problem. If it is spark knock, then you would be looking at things that can control your A/F ratio. If all those check out, you want to check out timing and your timing control components. If you are not getting enough voltage to the spark plug, you may get some spark knock.
Spark knock happens when the engine runs too lean.
Edit: I just re-read your paragraph, and that sounds like it may be a mechanical knock. Sorry
Old Jan 11, 2014 | 04:07 AM
Lord.Baal's Avatar
Lord.Baal
thanks for the help,
what does mechanical knock mean? what is the problem or what can i do to fix that issue?
thank you!
also i have always put in the highest octane gas i can get, 91, never have used octane boost before.
also at 100k (its at 104k now) i had the spark plugs replaced, but not the wires, could the wiring be an issue. it definitely gets worse the harder i pushed it so it sounds like that tells you something. i am going to avoid repeating it by only doing city driving until i can get it to a mechanic ASAP
Old Jan 11, 2014 | 07:33 AM
ynot d's Avatar
ynot d
Mechanical knock can be caused by excessive main or rod bearing clearance. This requires some expensive repairs to remedy. There are some other possible causes-see FSM.
Old Jan 11, 2014 | 09:08 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Sean, I know you had a pinging issue at the autox, is it a knock or ping? When you brought it over for your check engine light it ran real good.
Old Jan 11, 2014 | 12:39 PM
Kmcoldcars's Avatar
Kmcoldcars
I would suggest that you get on the proper regional forum and ask for assistance in diagnosing the problem. You will find people with lots of knowledge that are willing to come and listen to your car.
Old Jan 11, 2014 | 02:11 PM
DanielRicany
thank you!
You may be mistaking the knock with a backfire. Check to see that your ignition wires are in the right plugs.
Old Jan 11, 2014 | 06:39 PM
Lord.Baal's Avatar
Lord.Baal
I am not sure if it is pinging or knocking, it sounded like pinging at first but now it feels a lot harder then that. like the engine is cutting out. it could be backfiring, i wouldnt be able to tell the difference between those 3 different problems, just that the engine is making a strange noise and is cutting out as it gets pushed harder.
i just called the dealer up here and am going to have the corvette mechanic take a look at it to try to diagnose the problem, i dont want to keep repeating it if it is damaging the engine.
thanks for the help!
Old Jan 11, 2014 | 06:40 PM
Lord.Baal's Avatar
Lord.Baal
it seemed to be running fine until a month or 2 ago when i noticed some pinging at high speeds and high acceleration, no lights are coming on even now which the service guy thought was strange when i was talking to him.
i wish i could tell the different between knocking and pinging
Old Jan 11, 2014 | 07:22 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Just a thought how's the exhaust flow? Think your cats could be stopped up?
Old Jan 11, 2014 | 08:03 PM
ghoastrider1's Avatar
ghoastrider1
another " just a thought".. wonder if timing has changed due to wear or what ever.
Old Jan 11, 2014 | 09:05 PM
DanielRicany
Does it sound like a chatter? If so, adjust your valves.
Old Jan 11, 2014 | 09:24 PM
Lord.Baal's Avatar
Lord.Baal
how would i be able to tell if they are backed up? is there a simple way to measure that?
i hope its something like timing that can be fixed, not something i can do but hopefully the chevy mechanic can take care of it quickly.
and i would say no, it doesnt sound like chatter, more like pinging then just stopping
thanks for all the thoughts, i am not very mechanical but anything i might be able to test myself would be helpful, hoping the dealer will be able to give me a good answer when i take it in
Old Jan 11, 2014 | 09:45 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
I' not saying this is your issue just something to check, I had an 84 that stopped up the cats and it would not get past 3k rpms.
If your cats are stopped up the flow at the mufflers will be hot and slow, have someone step on the gas and it should increase. Your engine is like an air pump the more rpms the more air will pass through it, if the cats are stopped up it can't get the air out.
Old Jan 11, 2014 | 09:49 PM
DanielRicany
I had a similar problem, but my 85 has very low compression I believe 9.0:1. It didn't knock, but you may have a problem with the computer controlling timing. Make sure your EST wire is plugged in, because when I left mine unplugged the car wouldn't go passed 4,000 RPMs.
Old Jan 11, 2014 | 09:54 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Its an LT1 with an opti-spark
Old Jan 15, 2014 | 12:27 AM
Lord.Baal's Avatar
Lord.Baal
Kim, you totally called it. it was my EGR, it was totally shot, having it replaced tomorrow along with getting the injectors cleaned, had a lot of carbon buildup and was causing the pinging and loss of power.
really glad it was relatively cheap and nothing to serious, should have had that done as soon as you told me that was probably what was making it ping, you do know your 90's c4's!!!
To engine problems, help please
