Dash cluster
Old Feb 9, 2014 | 05:16 PM
wireman's Avatar
wireman
5th Gear
Default Dash cluster
I replaced a cluster with one I got eBay and it acts like a light show for about 10 secs and then disappears. The seller has been around and I emailed him I just haven't heard back yet.anyone ever have this happen.wondering if there's something else to look at before I ask for a replacement. Any thoughts are much appreciated. Thanks in advance
Old Feb 9, 2014 | 07:17 PM
WVZR-1's Avatar
WVZR-1
Pretty hard to offer up advice or try to help when there's no mention of what it is that you're looking for. What year and for what reason did you believe that you had a cluster issue to start with?
What were the original problems? Do you have both the old and the eBay cluster side by side?
Old Feb 9, 2014 | 08:06 PM
Karsten's Avatar
Karsten
On my 1993 I bought a new/rebuilt LCD as the original was unreadable. I also found 4 of the 5 bulbs were burnt out. I replaced the screen and 5 PC161 bulbs and all is good.
Karsten
Old Feb 10, 2014 | 05:25 AM
wireman's Avatar
wireman
5th Gear
Thanks and sorry for so little info. 88 c4 - original problem just like Kirsten said,barely readable,replaced it with one from eBay 6 yrs ago and all was fine,simple enough ,plug play. This time half the display went out and the rest of it was no working. So replace again ,this time the cluster just starts flashing through its light display and stops. Original question really was"is there something else that I can try before I remove and send this back to seller". If so please chime in. Thanks
To Dash cluster
