93 lt1 auto computer
Old Feb 23, 2014 | 08:21 PM
vetteOnTheRun's Avatar
vetteOnTheRun
Default 93 lt1 auto computer
Guys in a freak accident my computer for my 93 auto got damaged. It has the code BDBK 4779 on it. Do I need to get that same one for it to work or can I get another that will work? Also where is the best place to find one? Please dime in. Thanks
Old Feb 23, 2014 | 10:19 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
-First, remove your memcal from your current ECM. You will need install it in your new or rebuild ECM.
http://www.espritfactfile.com/removememcal.html
-The ECM you are looking for is p/n 16159278. They are not that easy to find, you might be able to find them at a part store, or ebay.
-For a rebuild, you may want to try these guys.
http://kandbcorvetteproducts.com/cor...gine-controls/
Old Feb 24, 2014 | 06:26 AM
vetteOnTheRun
James,
I should have been more clear. It was the memcal that I damaged. The ECM is ok.
Old Feb 24, 2014 | 06:54 AM
WVZR-1's Avatar
WVZR-1
James,
You would like the same PROM codes that you have presently. I would think that shouldn't be difficult but you'll either need to post WTB here or have reasonably good luck in a salvage situation. In a salvage situation you would likely need to purchase the ECM also. A used ECM should likely have a label still on it with the code.
You need to watch buying PROM from someone that mentions they can do one for you. You need a "correct" PROM to start with, not the same code but the same base hardware.
Old Feb 24, 2014 | 08:57 AM
vetteOnTheRun
Originally Posted by wvzr-1
you would like the same prom codes that you have presently. I would think that shouldn't be difficult but you'll either need to post wtb here or have reasonably good luck in a salvage situation. In a salvage situation you would likely need to purchase the ecm also. A used ecm should likely have a label still on it with the code.
You need to watch buying prom from someone that mentions they can do one for you. You need a "correct" prom to start with, not the same code but the same base hardware.
10-4.
To 93 lt1 auto computer
