1994 C41 Code and SYS
1. Car will start when clutch pedal is buried in the carpet. The clutch switch is in a location where my big head, shoulders and arms will not go. Even if all I want to do is bypass the switch.[B] Is there a way to adjust the switch or get at it more easily?
2. When I start the car it runs for a few seconds then stops. The codes come up as follows.
1. C41
4. ERR
9. ERR
A. ERR
I found a purple wire in the red plug in the PCM that was pulled out. It was a ground from what I found. Plugged it in but no changes.
I checked for corrosion on the PCM connectors and found none.
I checked all the fuses and found none blown.
I have the two volume GM Service Manual and the CCM Book. I see what they are asking me to try on 8D-55 in Book 2 but again, big head will get in the way.
Based on the car seating around not being used, what do you think the most obvious problem could be?
Thanks,
Jack
