84 c4
Old Mar 1, 2014 | 09:51 AM
rbynum's Avatar
rbynum
6th Gear
Default 84 c4
I am moving from florida to Oklahoma and I am towing my vette behind my motor home on a dolly. if I do not disconnect the drive shaft is there a possibility of doing any damage to anything? it is a standard trans.
Old Mar 1, 2014 | 10:02 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Personally, I'd NEVER use one of those dollies. A would opt for a trailer to put it on since you're traveling so far. The back end of those dollies tend to wonder around a bit and pulling one end of the car all that way just would make me a little nervous. If you must use the dolly, the safest bet would be to definitely disconnect the driveshaft.
Old Mar 1, 2014 | 09:00 PM
DinoBob's Avatar
DinoBob
Dude, get it shipped. It is cheaper than you think.
Old Mar 2, 2014 | 05:17 AM
WVZR-1's Avatar
WVZR-1
I believe I'd opt for the "ship it" also. The drive-shaft removal isn't a "piece of cake" and to do a "dolly transport" you would need to remove the C-beam and drive-shaft THEN reinstall the C-beam, dolly the car, remove the C-beam again, install drive-shaft and install the C-beam again. There is NO way around that procedure.
A C4 will fit a U-Haul with little effort if you insist on the towing yourself.
Old Mar 2, 2014 | 08:06 AM
rbynum's Avatar
rbynum
6th Gear
already got quotes but thanks for the advice
Old Mar 2, 2014 | 08:07 AM
rbynum's Avatar
rbynum
6th Gear
thanks for your input
Old Mar 2, 2014 | 08:08 AM
bac22's Avatar
bac22
Trailer if you can't ship!
To 84 c4
