Help with keyless entry install
Old Apr 1, 2014 | 12:37 PM
C4life's Avatar
C4life
Default Help with keyless entry install
Hi guys, my car is a 90, need your help to install a viper keyless entry. I cant locate the unlock wire from underneath the drivers kick panel. From the door bundle I was able to find the lock(light blue) wire and unlock is said to be black and theres like 4 of them
can anyone with the experience help pls.
thanks,
Kevin
Old Apr 1, 2014 | 02:57 PM
Chuck Tribolet's Avatar
Chuck Tribolet
Are you looking at a '90 FSM? Or something else?
The Haynes manual electrical schematics are for an '84.
For my '87, I had to make the lock/unlock connections inside the
passenger's door.
This may be helpful:
http://www.garlic.com/~triblet/RemoteKeylessEntry/
Old Apr 1, 2014 | 05:55 PM
MRPVette's Avatar
MRPVette
It should be right next to the light blue wire they will both be pretty thick gauge wires just use a test light when hitting the unlock button.
Old Apr 1, 2014 | 06:34 PM
C4life's Avatar
C4life
There's one thicker gauge black wire and the rest are smaller, is that the one? The light blue is the same size as the small black wires.
Old Apr 1, 2014 | 10:30 PM
MRPVette's Avatar
MRPVette
They should both be pretty thick wires.
Old Apr 1, 2014 | 10:43 PM
C4life's Avatar
C4life
I'll snap a pic tomr
Old Apr 2, 2014 | 12:27 PM
MRPVette's Avatar
MRPVette
I would look at mine but it is a 95, 90-93 is different it has been 7 years since I installed alarms but here is a great resource I used to use for keyless entry and alarms. http://www.the12volt.com/
Old Apr 18, 2014 | 02:59 AM
C4life's Avatar
C4life
Finally had a chance to install the keyless, I used the diagram from 12v but can't find the correct wires. There's two blue wires one thicker gauge then other for "Lock" and there's two thicker gauge and 2 smaller black wires for "Unlock" I can't seem to find the correct one. This is all coming from the door loom. Iam looking in the right place?
Old Apr 18, 2014 | 03:21 AM
Cliff Harris's Avatar
Cliff Harris
You need a test light or meter to probe the wires while locking and unlocking the door.
That's the only way to know for sure you have the correct wires.
Old Apr 18, 2014 | 10:07 AM
AlaJoe's Avatar
AlaJoe
I just put a remote start / keyless entry into my 93. I had a lot of trouble with the door locks. I think you got the wrong color wires read my post at "the12volt" forum
http://www.the12volt.com/installbay/...asp?TID=135982
Old Apr 18, 2014 | 12:14 PM
C4life's Avatar
C4life
This helps a lot! Thanks! I'll give it a try later and report back.
Old Apr 19, 2014 | 09:02 PM
C4life's Avatar
C4life
I tried it with the two wires you used, Blue/white and black/white both thicker gauge wires but I still get nothing. I'm using the Viper 211HV keyless. Can u explain the diagram with the relays in your post? I'm kinda confused and want to make sure I understand, thanks.
Old Apr 19, 2014 | 10:20 PM
mixalive's Avatar
mixalive
Here is a thread i started on this install. I hope it helps you out.
https://www.corvetteforum.com/c4-tec...ss-module.html
Old Apr 20, 2014 | 12:38 AM
C4life's Avatar
C4life
That's far too advance for me to understand lol, I simply just want to install a keyless which requires only two wires from the car and I can't even get it to work (
Old Apr 20, 2014 | 01:33 AM
Black LS2's Avatar
Black LS2
Do you have electric lock switches in the doors?...my 87 did not. Had to run the cross wiring on my own. Also, there is no lock relay in a 90 like there is in an 84.
Old Apr 20, 2014 | 11:28 AM
C4life's Avatar
C4life
Yes my car does have electric lock switches, I'm pretty sure I got the wires wrong somehow. I'm taking both lock/unlock wire colors from the door loom, those are then connected to the Viper module, with power and ground hooked up. The Viper module clicks when I push the lock/unlock on remote but door locks do nothing.
Old Apr 21, 2014 | 08:02 PM
mixalive's Avatar
mixalive
This is where i mounted my LED. It illuminates the speedo screen at night.
To Help with keyless entry install
