Lowered C4's
Old May 18, 2014 | 03:56 PM
  #41
smdorsey's Avatar
smdorsey
DRM Coilovers are next for me. My 96 sat up like a scared cat. Originally installed the wedge and 10 inch kit from VBP but could not get the car low enough. Both springs had some serious arc. VBP wanted an arm and a leg for their 12 inch bolts so I bought some threaded grade eight rods, cut to 12 inches, welded a nut on the top and was done for under 15 bucks. Front is still too high with both the top of the wedge and half of the spring end pad removed. Luckily DRM is only a couple hours away from me.
Stay Frosty!
Stephen
Old May 18, 2014 | 05:55 PM
  #42
USAZR1's Avatar
USAZR1
It seems we have two camps here. One group utilized the simple,less costly wedges & longer bolts for good results,with a few exceptions. The other group thinks that coilovers are the only option. Both ways will work in lowering the ride height but at a big difference in cost.
The 3rd option,a VB&P adjustable front spring,has only been mentioned once but it obviously works well. Wonder why so few don't give it a try?
Old May 18, 2014 | 06:54 PM
  #43
Karsten's Avatar
Karsten
I have the lowering kit from Eckler's with the wedges and longer bolts for the rear just haven't found the time to install them yet.
Karsten
Old May 18, 2014 | 07:13 PM
  #44
GKK's Avatar
GKK
Originally Posted by USAZR1
Our 94 is in need of an "attitude adjustment" and I'm trying to decide the best way to lower it within our budget.
For what you have asked, you just need to cut the stock rubber wedges down and use the 10" lowering bolts for the rear.
Simple and Inexpensive...
This is what it'll look like afterwards...
Old May 18, 2014 | 07:40 PM
  #45
USAZR1's Avatar
USAZR1
Looks like my car is almost there now,stock. Another inch lower is about all that's needed. What do you guys think?
Old May 18, 2014 | 08:54 PM
  #46
GKK's Avatar
GKK
It's hard to tell by the photo's but, lowering will make a noticeable difference. I can see your front spoiler sits higher than on my Vette.
If you install the aftermarket lowering wedges, the front will only drop about 1/4"...
If you shave the stock wedges and rubber pad ends, the front will look like the pictures I posted. The new wheels are 19"x10" but, the tire height is the same as with the 17" tires.
Two months later, I noticed the front dropped another 1/4", which looks even better now!...
Old May 18, 2014 | 09:52 PM
  #47
9T3VETTE's Avatar
9T3VETTE
Did mine today..This is a zo7 car
I shaved the center rubber down to a thickness that was a bit thinner than the aftermarket wedges. Also cut half of the pads which contact the lower a-arm. One metal shim on each side was removed too. Overall it came down about 1.25" but it may settle more.
The rear was already lowered before.
Before:
After:
Old May 19, 2014 | 08:53 PM
  #48
kleptopigdog's Avatar
kleptopigdog
Found them ,I lost your number give me a call!
Old May 19, 2014 | 08:59 PM
  #49
DanielRicany's Avatar
DanielRicany
Before:
After:
Wow! Those rims look dynamite on that car!!
Old Feb 23, 2025 | 09:36 PM
  #50
Bskrrush's Avatar
Bskrrush
Originally Posted by Winnin'
Like he said. Here's mine. This is an agressive drop. 2+ inches.
how do I get my height like yours
Old Feb 28, 2025 | 10:44 AM
  #51
BET VETTE's Avatar
BET VETTE
As low as these car sits, I’ll be frighten to lower it even an inch 😳
Old Feb 28, 2025 | 11:32 AM
  #52
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
I was gonna lower my 90, but decided on not.
It's alright the way it is...
Old Feb 28, 2025 | 07:31 PM
  #53
rad928music's Avatar
rad928music
Nice look. That body kit is Killer.
Old Jun 6, 2025 | 05:20 PM
  #54
CorvetteMan_94's Avatar
CorvetteMan_94
Navigator
Hi everybody,
Sorry for digging out an old thread. I recently imported a wonderful black 1994 C4 to europe and would need some help with the ride height.
Does anybody have measurements of the original wedges/rubber cushions sitting on the front leaf spring?
And how does cutting it effect the ride heigt? If I'll shave 1" off of the cushions, will it lower the Car by 1"?
Rear ist already adjusted.
Greetings
Sebastian
