6sp shift boot
Old Apr 15, 2014 | 12:47 PM
ramvet89's Avatar
ramvet89
Default 6sp shift boot
Hi
I have a 1996 convertible and recently purchased a new leather shift boot and console. Question is does anybody know what "bolts" are used to attach the shift boot?
Old Apr 15, 2014 | 01:49 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by ramvet89
Hi
The boot is attached to the console plate with some unique "nuts" that push over the nylon stud and is a tension retained part and then the boot is attached to the nut with a threaded fastener. It will become obvious to you when you disassemble your car. The "nut" is called an "on-sert".
Here's an image of an "on-sert" and in the lower left you can see how they're used for assembly. None of the sizes in that link are correct. I sourced these quite some time ago for a fellow but NOT from this vendor. This was just a very good informational link:
http://www.jetpress.com/Products.asp...appingThreads/
If you've received your parts PM me the dimensions of the plastic stud of your replacement console part. I can maybe duplicate them again. You could try posting a "wanted o buy" in the parts section also. The image should help you. Most aren't familiar with the product.
The screw should be an M4.2X1.4X13 that holds the boot to the "on-sert".
Old Apr 15, 2014 | 02:10 PM
ramvet89's Avatar
ramvet89
Thanks very much for the quick reply - when I took the console apart the boot was attached to the cover with machine bolts - I have seen the on-sert before and now that you identified the part hopefully I can locate the correct size since the new cover didn't include the on-sets
Old May 6, 2014 | 11:29 AM
ramvet89's Avatar
ramvet89
Just an update - I was unable to locate any of the on-serts so I searched for a different resolution - what I did was use inserts from the hardware store that were intended for use in wood - I filed down the "threads" then used super-glue to help keep the inserts in place and used 6-32 machine screw with a flat washer to attach the shift boot - looked factory installed and is holding solid as a rock
To 6sp shift boot
