replacing fuel pump
Old Apr 29, 2014 | 02:09 PM
jisslebissle's Avatar
jisslebissle
7th Gear
Default replacing fuel pump
So I'm replacing the fuel pump in my 96 and for the life of me cannot get the top hose off. I got the other two on the bottom off. I really don't want to cut and have to replace the top one. Does anyone have any suggestions as to how to get the stuck hose off? Thanks in advance.
Old Apr 29, 2014 | 02:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On my prior '88 all three hoses were pretty well "stuck" onto the pipes but working the rubber back & forth with a pair of vice-grips did the trick with no hose cutting needed.
Old Apr 29, 2014 | 03:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Apr 29, 2014 | 03:40 PM
mixalive's Avatar
mixalive
When you try to pull the hose off, it tries to tighten up around the metal hose. Kinda like the Chinese Finger Trap.
What you do is pry up the end slightly with a small flat blade screwdriver and spray some silicone lubricant at the joint. It will draw the lubricant up between the metal tube and rubber hose. Then take a large flat blade screwdriver and push the rubber hose from the end.
BTW.. Make sure to replace the sending unit gasket as this is a source for moisture to be drawn by vacuum into the fuel tank while driving in the rain. And clean the drain tube as well for the same reason.
Old Apr 30, 2014 | 01:11 AM
jisslebissle
7th Gear
Thanks guys. I've got the thing replaced. The problem now is that there is static coming through my radio... wtf? It seems as though the faster I drive the less static there is. Could it be that I didn't a connector in good enough? That seems unlikely though.
Old Apr 30, 2014 | 01:31 AM
Cliff Harris's Avatar
Cliff Harris
I use pliers opened up to the large position and twist the hose to break it loose.
Old Apr 30, 2014 | 03:18 AM
65Z01's Avatar
65Z01
Does the frequency of the static increase/decrease with engine RPM?
Old Apr 30, 2014 | 11:52 AM
jisslebissle
7th Gear
No it doesn't increase along with the rpm
Old Apr 30, 2014 | 01:36 PM
mixalive's Avatar
mixalive
You are probably hearing the whine of the HP fuel pump.
To replacing fuel pump
