What did you do to your C4 today?
MSGT-R (09-18-2016)
#2024
Took a nice ride to Indy and back, About 80 miles total
Perfect weather, got another corvette wave from a fellow enthusiast.
He was driving a beautiful teal 90 c4
Thumbs up both ways , great fun
Monte
Monte
#2025
Finished up with the leather conditioner on the passenger seat.pulled the lower cushion out and found the frame had signs of moisture. So now will clean the framework and put a coat of wax on it. Guessing the drivers seat is the same. Adjusted the head light closing.
#2028
It looks really nice. Did you consider black walnut for your console cover? Just for grins, I think I may have wanted something a little darker in natural color.
#2029
Painted Flowmaster 40 series Mufflers Black
Hot day in Socal, and I decid3d to get busy painting the flowmasters with high heat paint. Yesterday I removed my spare tire setup and polished my pipes...coming together nicely in my opinion. Collector editon 96 lookin like 16 at this point Randy your Zr1 is bananas in a good way!! Haaaa
#2030
Took the 91 ZR1 For a little spin then to the petrol stop for the good stuff.The issue of a vaccum leak under the plenum seems to have stopped.After the drive, the fuel pump cycles as it should. Perhaps something was just stuck from lack of use? No problem. I still need to order the new headlight gears and bushings and then install them. Then pull the wheels and fender wells to clean the suspension parts.seems odd for a car with only 11k, but then it is 25 years old.
#2033
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Well in the last 15 years only drove with the top out once if that tells you anything But I have driven may C4's with out the top all acted the same felt lose.
Have not driven it yet, but bars in headed out to a car show in the morning 80 miles one way I'll let you know
#2037
Repaired the EGR Tube Massacre of 2016. Stupid little tube split, flipped up and murdered stuff under my hood. Burnt through passenger hood cable, distributor cap, rotor, ignition module, and coil. What a mess. Got it all replaced, repaired, and running.
#2039
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
C4 of Year Finalist (stock) 2019
St. Jude Donor '08
Started my old '87 and drove it down the road for the first time in almost 8 years.
#2040
I removed the old injectors since one of them was leaking at the top o-ring. Originally I planned on immediately throwing the Bosch III's I got from Jon today in and then going for a drive, but I like to tinker so I figured it was time to try my hand at porting the plenum. Now Amazon just needs to get my Dremel and accessories here so I can do some more work. :-)
