Battery Draw Test ??
Old May 6, 2014 | 09:17 AM
popps9's Avatar
popps9
Default Battery Draw Test ??
Ok so now I figured I better do a draw test, put my multimeter in series on the battery and with everything off when I touch the terminal the headlamp motors (both) start to turn and the meter reading is extremely high ( 700-800 ma) and fluctuates. as soon as the headlamp motors stop ( about 4 seconds) then the reading drops to 0. So any thoughts from any one would be very appreciative. I got to get this straightened out -its cruising time and I cant be carrying a jump box in a Vette. ewwwwww
Old May 6, 2014 | 09:36 AM
WW7's Avatar
WW7
If you have the meter hooked up properly the reading should never drop to zero, there should always be a reading somewhere around 25ma, to a maximum of 50ma .. Try unpluging the headlights and then taking a reading to see what you get...If the headlights are flipping over without you pulling the headlight **** then I would say that could very well be your parasitic drain..Im not an electical expert like a few of the guys on here, but it may be a bad headlight switch or a short in the wires...Hopefully the electrical guys will chime in...... WW
Old May 6, 2014 | 10:54 AM
c4cruiser's Avatar
c4cruiser
Might be a relay sticking open that causes the motors to run when they should have stopped. The headlamp switch would be another possible culprit.
You really need to get a Factory Service Manual set for your year of C4. The '92 FSM is a two book set. The second book has complete wiring diagrams for each component and a step-by-step troubleshooting procedure. Pics of the locations of relays, fuses, harness connectors are all there. The wiring diagrams also show the ground wiring circuits and where the grounds connect to the frame.
The C4 Parts For Sale section would be a good place to start searching for a '92 FSM. Make sure the books have red covers.
Old May 6, 2014 | 11:20 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
4 seconds is roughly the amount of time it would take to do a complete cycle open or close.. How does the motor work if you put the headlights on and off? Do you get the extra run on when it is open and then when its closed? If you have the same run on or jerky operation, might be time for new pellets..
The later C4's don't use relays they have a module that controls the operation of the motors.. I agree on the need for the FSM..
[IMG][/IMG]
Old May 6, 2014 | 02:00 PM
popps9's Avatar
popps9
I rechecked it, I get 3.1 amp when I first touch terminals then after the motors stop turning (headlamps do not go on and doors don't open) then it drops to .16 amps. I'm thinking I believe theres a relay and maybe its bad. The headlamp motors I believe always turn when I would turn on the key
Old May 6, 2014 | 02:13 PM
ccrazor's Avatar
ccrazor
As stated by WW7 the maximum draw s/b no more than 50 ma or .05 amps. As I stated above if you have a 92, there are no relays for the doors but a module, see drawing.. You need to start pulling fuses until you find the circuit with the draw, make sure the under hood lights are unplugged and any open door switches are blocked closed..
Did you try operating the headlight doors with the switch?
Old May 6, 2014 | 02:39 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Here is a helpful video made by Forum member Flyboyslc1
Old May 6, 2014 | 02:52 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Ummm, did you remember to unplug or turn off the under-hood lights??
Old May 6, 2014 | 09:19 PM
WW7's Avatar
WW7
Also when checking for a drain, you have to wait for the interior lights to time out, this usually takes a minite before you can get an accurate reading... I always use a jumper wire from the battery to the cable so I don't lose all the information, radio, clock, etc, and so the ecm doesn't have to relearn everything.....WW
Old May 7, 2014 | 08:48 AM
bac22's Avatar
bac22
Pull fuses until you see the current drop to 30-50mA. When you see the drop than you've at least troubleshot the draw down to a particular circuit and go from there.
To Battery Draw Test ??
