vats
Old May 18, 2014 | 01:36 AM
gremlin12's Avatar
gremlin12
Originally Posted by vetteoz
So which problem do you ACTUALLY have
The one where it won't crank over (could be related to the security system )
or one where is won't fire up without spraying fluid ?????
Two completely different unrelated problems.
the horn will go off and i put the key in and the horn will not turn off and it will not crank i just want to do away with the hole thing
