Preventive maintenance?
I'm a new member and just bought my 'new', stock, automatic, 1985 7 days ago with 108,000 old man miles. I flushed the brake system. I'm adding new plugs, wires, cap/rotor this weekend as well as coolant flush and fuel filter. I have ordered a fan switch and thermostat from CC for cooler running. The trans will get a full flush the following weekend. I don't have a FSM yet but hope to get all the grounds leaned up ASAP. The car was driven 17,000 miles in the last 15 years but was kept in a heated garrage. After cleaning a sticky TB, it runs and drives great!
I saw a list on corvsport of common issues with the 1985 which included failing oil pressure switch; fuel pump relay; ignition module; TPS; MAF sensor; PROM
I want to use the car for trips up to the MN woods and was wondering what the consenus was on replacing some of these parts before failure? If the car lasted 108k miles could one assume that, 1: faulty parts have already been replaced, or 2: the parts lasted this long and should be good?
What about the ancient fuel pump?
Thanks for the help!
My prior '88 had 92k on the clock and it failed, leaving me waiting for a flat-bed.
I would suggest you put some miles on the car before venturing very far into the wilderness.
The best way to change out the coolant is to remove the plug in the block on the driver's side and the knock sensor on the passenger's side. There may be a rust build up over these on the inside of the block. Just poke a screwdriver thru the rust.....be prepared for a RUSH of coolant.
Check behind the radiator for debris build up. Take the top off that is over the radiator and clean this area out down low. These cars are bottom feeders and pickup all kinds of things that get stuck in this area.
Be aware that the automatic trans are good for between 100,000 and 120,000 miles approx. before the need to be rebuilt.
PM Sent to you.
I'd finish up by doing the full fuel system including fuel filter, new fuel pump, Fuel pressure regulator, fuel rail and inlet o-rings, and maybe injectors if they have not already been replaced. Even at 16K miles, I has a lazy/dead injector on #7 cylinder so miles has nothing to do with it. just did this job last weekend, some part numbers:
Rail O-ring kit:
GP Sorenson 800-9211 or bwd 274773 (usually in stock at autozone)
Fuel inlet orings BWD 21720
Regulator diaphram GP Sorenson 21720 (also in stock at autozone)
Good idea to replace the EGR valve while the Plenum is off.
I used the updated "OEM" Delphi injectors and they are indeed spot on for the factory tune on my '89. BLM's are dead on.
As was mentioned, the fuel pump is real easy @ 30-40 minutes, just make sure you have a new gasket and O rings for the perimeter bolts prior to doing this job. Ask me how I know
Rear end diff fluid change is a piece of cake. Dropping the pan on the auto, replacing the filter, and flushing out the old fluid front the front of the car is a 2-3 hour job taking your time.
Other than that, you might want to do factory service stuff like setting up the base idle, TPS voltage set, and IAC reset etc. 1 hour
Also might not be a bad idea to check all of the vacuum lines and plenum for leaks. I like to use the cigar smoke technique. Just seal up the front of the throttle body and blow smoke into the plenum via the brake or PCV ports. If you have a vacuum leak, this is a sure way to find it! 1 hour
Just a word of caution on removing the thermostat. It is common for the 3/8 bolts to be rust welded on the manifold. Don't force the bolts out. If you manage to get them out a few turns and they get stiff, STOP. Use PBblaster and spray the threads and let it sit for a few hours and then consider just screwing them back in and leave well enough alone. If you proceed, slowly turn the bolts in and out to loosen up the rust. If you snap a one of these bolts, you'll curse the heavens, trust me on this one.
I've flushed the fluid twice since 70k (7 quarts of Mobil 1 Full Synthetic trans fluid added each time) and installed a heatsink trans cooler at around 90k.
Anybody in Canada know where the best place, online of offline, is to get c4 parts at the best price?https://www.corvetteforum.com/forums.../Cdnsmilie.gif
don't screw with the maf- they're expensive...your chip is good...the hperchips do not work...your vette will throw a code if they become a problem....the fuel pump is another issure...convette central has some nice stainless pumps and sending units....easy installation....get a fsm GM....at e-bay......you'll absolutely need it....post some pics....guys get in the habit of throwing parts at the engine...tps is fine....you'll know if it's not working.....lots of threads here to due regular maint....timing/ tps/ minimum idle adjustments.......have fun.....don't forget to write...
Car was driven 17,000 miles in the last 15 years but was kept in a heated garage.
coolant flush and thermostat
fuel filter
fan switch
trans full flush
A few very important components your overlooking. Tires, shocks, air filter and diff fluid. And battery. Keep your battery topped with a battery tender, or you'll be replacing the alternator as well. Check all the grounds in the engine compartment especially those around the battery.
I carry a battery cable cutter, fire extinguisher within easy reach. A FP and MAF burn-off relay, serpentine belt, an ignition module and spare t-stat. All of which can fit in the passenger side rear storage compartment.
Once your car starts to get used, you'll begin to find oil leaks and other problems that will appear. So that FSM is a must have to trouble shoot and assist with repairs. Parts can be found on Rock Auto, eaby and of course the vendors here.
Tommy
i figure if you own your C4 long enough, you'll replace or repair just about everything at least once. seems there no end to it, but still having fun!!!
BTW, love the avatar shirt!
Good luck with it!
AND..............
