Incorrect build sheet? Help!
Old May 17, 2014 | 11:19 AM
PS961's Avatar
PS961
Suspended by request 21 May 2014
Default Incorrect build sheet? Help!
Hello everyone, I just purchased a Grand Sport and after I got home I was looking at the build sheet and window sticker and the build sheet says it has RED interior, Y01 and the window sticker says BLK/RED interior.
THE CAR HAS BLACK INTERIOR!
The VIN is a grand sport and I have all the paperwork and everything so I don't believe it could be a fake or anything, that being said:
-could they have made an error on the build sheet?
-could they have ran out of RED and built the car with black?
-could someone have swapped interiors after it was built?
-anything you can suggest or help me with, PLEASE!
I am very confused but also very worried.
THANK YOU!
Old May 17, 2014 | 11:31 AM
WVZR-1's Avatar
WVZR-1
THANK YOU!
195 is a black interior and 705 is the red/black. Could they have been changed? Maybe? Not familiar with the Y01 you mention. What is in BLOCK 55 - 19I? Does SPID label show 19I and then 195 directly following or is there a 705 there?
You mention "worried"? Might be late if the deal is done you've the car and someone else "your money".
Old May 17, 2014 | 11:35 AM
PS961's Avatar
PS961
Yep, the build sheet says 701, which I translated to RED.
To previous owner said he knows nothing about it. I joined the registry and hoping the get previous information from them, it just confuses the hell outta me!
I am nervous something fishy may have gone on, I spent a lot on the car just want to make sure it is what it is.
http://www.lbfun.com/warehouse/tech_...PO%20Codes.pdf
Old May 17, 2014 | 11:52 AM
WVZR-1's Avatar
WVZR-1
There is no 701 - 705 is GS only blk/red. There is a 70I and that is a red interior. Are you sure all of your documents match? What does the SPID label say? Does the VIN match on all three documents?
What is the last eight digits of the VIN? T5XXXXXX
c4cruiser's Avatar
c4cruiser
THANK YOU!
The GS Registry should be able to help with the correct information regarding the interior color. I don't think that there was a possibility of the Assembly Plant running out of material.
It's possible that a previous owner could have swapped out the various interior pieces, but that would be a big job and expensive too.
Have you looked here? The GS Registry has this list of the 1000 cars and includes the interior color. Also look at this page for the RPO codes. I would expect that the GS Registry website will have accurate data.
Are both the build sheet and window sticker original to the car or are they from the National Corvette Museum? It's possible that there could be an error, but the data that the NCM uses to produce their documents comes directly from GM.
Old May 17, 2014 | 11:59 AM
wfd1739's Avatar
wfd1739
THANK YOU!
What number GS do you have?
http://grandsportregistry.com/faq.htm
Visit this page. It has all the info you will need to authenticate your GS.
Also check out the buyer guide page. As well as the vin list page.
Old May 17, 2014 | 12:02 PM
PS961's Avatar
PS961
All documentation matches in regards to the VIN number.
Old May 17, 2014 | 12:04 PM
PS961's Avatar
PS961
I contacted the person from this forum who sold it to me and he said he has no idea why it has black instead of red.
Old May 17, 2014 | 12:06 PM
WVZR-1's Avatar
WVZR-1
T5600961
That VIN using the GSR documentation should display on the SPID label 19I and 705 I would think.
Old May 17, 2014 | 12:07 PM
PS961's Avatar
PS961
I will go snap a pic..
Old May 17, 2014 | 12:11 PM
wfd1739's Avatar
wfd1739
T5600961
The registry has 961 as a red guts car.
I can tell you I own #791 which was originally a black interior car that was changed to a red interior car.
Old May 17, 2014 | 12:13 PM
WVZR-1's Avatar
WVZR-1
I would guess that the "red" seating being quite valuable the seats were swapped for a fairly substantial amount of "cash" if in fact the SPID and build mentions "RED"!
Old May 17, 2014 | 12:15 PM
WVZR-1's Avatar
WVZR-1
Are your seats just "red" or the correct embroidered pieces? I believe I was just looking at your car on buy-a-vette
Did you get all of your wheels?
Old May 17, 2014 | 12:21 PM
wfd1739's Avatar
wfd1739
Old May 17, 2014 | 12:30 PM
wfd1739's Avatar
wfd1739
I did. Have not installed yet as I am trying to decide which tires to put on.
Old May 17, 2014 | 12:45 PM
PS961's Avatar
PS961
So is the best explanation you think? Someone changed it over?
So then it makes my car far less valuable?? Maybe I got hosed here?
Old May 17, 2014 | 12:50 PM
wfd1739's Avatar
wfd1739
Can you post a picture of your service parts id sticker located in rear compartment.
To Incorrect build sheet? Help!
Old May 17, 2014 | 12:55 PM
wfd1739's Avatar
wfd1739
At this point unless you bought the car as an investment which may or May not give you a return on your money in 10 or 20 years, I
Would drive and enjoy the car. You knew it had black interior when you bought it.
Old May 17, 2014 | 12:56 PM
PS961's Avatar
PS961
I will I just had to run out for a little bit I will get it up within the hour.
Old May 17, 2014 | 12:57 PM
PS961's Avatar
PS961
I absolutly will but the car is bone stock and I would love it if the interior was as well. It has black grand sport seats but just not the red
