Radiator Drain Plug
Old May 18, 2014 | 10:16 PM
da3093's Avatar
da3093
Cruising
Default Radiator Drain Plug
I flushed the radiator on 86 c4 and now it appears that the drain plug is leaking. Has anyone experienced this before?
Old May 18, 2014 | 11:14 PM
Joe C's Avatar
Joe C
I haven't, but my son has on his 85. seems to me he bought a new drain plug at autozone, or advanced auto. must have worked, since he never said any more about it.
Old May 19, 2014 | 09:40 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Yes, it happened to me also. Exact same problem. I went to Advance Auto Parts and got a new plug, Any auto parts store should have it. It was only a few dollars and very easy to get the old one out and install a new one. No more leak!
Old May 19, 2014 | 10:36 PM
da3093's Avatar
da3093
Cruising
I put a new plug In it today. No more leaks
Old May 20, 2014 | 09:17 PM
wydopnthrtl's Avatar
wydopnthrtl
For future searches:
I flushed my 95 a few days ago. The plug has a flat rubber washer on it that fits snugly over the center rod. A guy could go to the local hardware store and get a flat rubber washer and make it fit or maybe trim the outside & center out as needed.
Old May 20, 2014 | 09:28 PM
WVZR-1's Avatar
WVZR-1
Why would you want to McGiver something that there's an "over the counter" correct solution for?
Old May 22, 2014 | 04:22 PM
tntwolt's Avatar
tntwolt
This drain plug, it's actually a plug? Not a valve? I couldn't see it so I shop vacuumed coolant out.
Old May 22, 2014 | 05:31 PM
da3093's Avatar
da3093
Cruising
It's actually a plug that unscrews. It's on the passenger side bottom corner of the radiator
Old May 24, 2014 | 05:22 PM
tntwolt's Avatar
tntwolt
I was afraid of breaking something. I think the shopvac got to the bottom of both tanks anyway.
To Radiator Drain Plug
