I ordered a new dash top panel for my '89 from Corvette Central to replace the original one that had split. Of course, no instructions on how to install it. Has anyone ever done this before? How does it look?
Hi
Is straight forward remove the two screws at the demister outlet, then remove two screws above the center dash vents.
Now pull the dash towards you, the demister outlet gap is a nice place to pull it (needs quite a bit of effort but it pops out easilly), if you still have the speaker mounted to the dash pad check for it and lift the dash pad up and back. Disconnect the speaker wires and remove the dash pad completely.
Now for installation, place the dash pad and slide toward windsheild.
Leave a couple of inches and press the dashpad down while sliding it in place, there are four tabs that lock onto the windsheild frame and hold it down. Check the sides are down and nothing sticking up.
Then reattach the screws and you are ready for a test drive
Done it before, pretty straightforward once youre in there. Its a bit of a pain to get it in right while youre sitting in the car with it. I really recommend you make sure you don't drop or lose any clips or screws. Make sure that thing is snug in there before you put the plastic bezels back in.
Holy cats! I thought I was just buying some kind of slip-cover that went over the original padded dash top. So this thing actually replaces the old one, I guess. OK, I guess I can do it. Thanks, guys!
You had us confused. you will get sometype of glue to hold it down you will need to remove the 2 screws at the defrost duck. put down the adhesive slide it on and install the 2 screws. do not let the sun get near it as it will look like a wash board in no time. i tried 2 and got about 2 months out of each of them before they looked like crap. One day in 100 dg heat and they were toast. Good luck
If it's anything like the 84, there are 2 screws in the defrost vent and a total of 6 across the front.. 2 in the center and three on the left and one on the right end.. For the one om the right I had to remove the fuse cover and the side plastic.. On the center and left I removed the two bezels.. There are four clips across the back and also two on the front over the breadbox..
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Originally Posted by gerardvg
Hi Is straight forward remove the two screws at the demister outlet, then remove two screws above the center dash vents.
This is the way the screws are on my 89 also..The only difference is there is only 1 clip over the Bread box. Once all the screws are removed the pad has to be pulled straight back and then lifted up slightly to clear the front....WW
Thanks to all for your input. I just tried to remove the old dashtop speaker grilles (I have new ones) prior to installing my replacement dash cap. Gawd! They're - like - screwed in from underneath the dash or something. I can't get to them or even pry the *x!%$xx things loose from the top!. So, Is the only way to get to them to pull the dash, anyhow? Please, tell me there's another way to remove them!
they are screwed from underneath. Pad must come out
Yes it's expensive and it took me a couple months of searching for a nice dash pad. You can buy a excellent condition dash pad for $225-$250 shipped. Not bad compared to $400+ from a vendor. My own plan of attack for each hurdle has been to save the money and keep in mind how much it will improve the car. If you want you can just put a fabric pad over on it and forget about it. All the trouble I went to was to cover up the gap created when mine split. I still have the cover over top and you can't see it's new. But the gap has been closed so mission accomplished.
Problem is you are still buying a pad that is 20 years old minimum. It could crack the day after you put it in
I paid $125 plus $40 shipping for a reproduction dash pad. Never installed. I found it on Craigslist. I was extremely lucky. However I don't think if he buys a pad that is in excellent condition it will suddenly crack.I could be WRONG and it just might split right down the middle and his money wasted. He is the one who has to decide where to draw the line with cash into the money pit. I know where there is a pad out of a wrecked 1986 or 1987 that looks brand new. I inspected it in Carson CA. He is asking $225. At the time I did not have the cash or I would have bought it. I purchased a different part out of the same car. He has the parts inside out of the car.The sun in my opinion is why plastic gets brittle. A garaged car isn't gonna suffer the same as a car which gets lots of sun exposure.
Thanks to everyone who contributed to this thread. You were right with the number of screws and how to pull it loose and then get it back in again. The new dash cap and speaker grilles (all black) look great together. I AM A HAPPY CAMPER!
Please post some pics. This way somebody who is in your shoes can benefit by reading your story. I'm also curious how it turned out.
I'll try to post some but it may be a few days. Zip CV sent me two left-hand speaker grilles so I won't have the whole thing permanently assembled/glued in until I receive the right grille from them.
