Need advice please
Good luck in what ever you decide to do.
astepup said that
The issues: needs a headlight motor so right now headlights stay up,lights still work
Hatchback switch doesn't work but I have the part to fix it
Can't unlock door from driver side have to unlock from passenger has power locks
I bought the car last year off a guy who started doing the restoration and just didn't have time to finish.
The stingray 1976 Corvette Stingray. Dark brown w/ brown interior. sb350 w/ t350 trans.
- New Summit distributor
- New starter
- Engine is bored .060 over w/ Speed Pro pistons, Manley crankshaft and a Comp camshaft / lifters.
- New Holley 650 carb
- Hooker headers
- Included (but not installed) are 2 brake rotors, ball joints, power steering pump.
He said the motor has less then 1000k
I bought the 86.
Many of the C3s out there have windshield frame rot that you can't see and which extends down to the front of the door frame. The radiator support and rear dog leg portion of the frame are very subject to rust.
Stay with the C4s. Fix one of them up and sell it and take someone with you to look at the C3 - someone who knows what to look for.
I bought the 86.
Overall, the 76 is not a collector year by any means. C3's like the one you are describing would probably cost more to restore than the value of the car after you are done. Also, as a vette owner you are probably aware that normally people look for originality when they purchase a vintage vette. You 76 has a replacement engine which would turn off most buyers. It will take a long time before the value of the 76 climbs to anywhere respectable. I would keep the 86 if it were my choice.
Sledge_78
