C 4 lowering bolts
Old May 26, 2014 | 10:16 AM
tntwolt's Avatar
tntwolt
Default C 4 lowering bolts
What is the size of grade 8 bolts used to lower cars? Only want to go down an inch.
Old May 26, 2014 | 06:49 PM
gerardvg's Avatar
gerardvg
Bolts one inch longer will drop the car an inch.
Old May 26, 2014 | 07:54 PM
tntwolt's Avatar
tntwolt
Can't imagine driving a vette from the other side. Running the nut out to the end of the stock bolt may give me enough but I wonder if the cotter pin hole will be a weak point.
Old May 26, 2014 | 08:23 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Yes, it WILL be a weak point.
9/16" x 10" should do. I bought 2' of alloy ready rod and made them 11" ,to be sure I had more if I needed it.
Old May 26, 2014 | 09:02 PM
gerardvg's Avatar
gerardvg
The main issue is the right hand side floor is too damn narrow
Now here you go on the wrong side of the road in the RAIN. (they do not melt)
To C 4 lowering bolts
