Can anyone tell me where there is a good ground for an audio amp i am installing in the right rear cubby compartment??
Its a 1989 c4 coupe.
thanks
Mitch
I have my amp under passenger seat and use the seat track stud for it's ground. You could easily run the ground under the carpet to the stud, if you chose this route.
Thanks for all of the replys. And the ground diagram.
Mitch
I have my two amps in the rear compartment and also used the the seat stud for my ground. I found that the shorter the better.
