horn problem!!!
Old Jun 9, 2014 | 07:11 AM
roger2000's Avatar
roger2000
Default horn problem!!!
hi all, i fitted two new horns and think i may have crossed a wire at some point as they were working. now when i press the horn nothing but i can hear a click under the passenger side dash maybe the relay. i imagine power is getting to it as it's making a click so the fuse must be ok but not sure which fuse to check any ideas please?
Old Jun 9, 2014 | 09:46 PM
playsdixie's Avatar
playsdixie
the click is the relay....means the relay and button are ok...i'd be looking at the wiring job..
Old Jun 9, 2014 | 11:17 PM
Cliff Harris's Avatar
Cliff Harris
If the relay clicks (and assuming it's OK) the problem is in the horns or the wiring.
Check for 12 volts at the connector on the horn when the horn button is pressed. You also need a good ground for the horns. Usually that connection is made through the mounting bolt.
Old Jun 10, 2014 | 03:55 AM
roger2000's Avatar
roger2000
thanks i'm going to take them out and start from fresh
Old Jun 10, 2014 | 03:59 AM
roger2000's Avatar
roger2000
cheers for the update cliff. i'm going to take them out and start over. while i'm on guys my high brake light doesn't work. no power going to the wires when i put my foot on the break plus one bulb out. do all 4 bulbs need to be working for the connection to happen? any ideas where the wires go to from the light , connect / come out before i start dismantling
Old Jun 10, 2014 | 11:52 AM
playsdixie's Avatar
playsdixie
you need the gm manual before you go any further...they have them on ebay....then you can follow the trouble shooting guides & diagrams...makes it a lot easier....
Old Jun 11, 2014 | 01:23 AM
Cliff Harris
The high mount brake light should work no matter how many bulbs are working (or not). A friend of mine had 3 out on his '89 and the one remaining bulb still worked.
I think it depends on the year. On my car there is a separate switch on the brake pedal for the high mount brake light. I vaguely remember that on later years the two brake light switches were combined into one switch.
The switch might be out of adjustment. You push down on the brake pedal, push the switch forward and then pull up on the brake pedal. It's self-adjusting.
Last edited by Cliff Harris; Jun 12, 2014 at 01:21 AM. Reason: Corrected switch adjustment procedure.
Old Jun 11, 2014 | 07:35 AM
roger2000's Avatar
roger2000
The switch might be out of adjustment. You push it toward the brake pedal lever and then step on the brake (it's self adjusting).
hi thanks just took a look and no signs of any switches. sham that would be a nice easy fix
Old Jun 12, 2014 | 01:19 AM
Cliff Harris
You must not be looking very hard. The brake pedal has several switches on it. One is for the brake lights (obviously). There is a combination electrical and vacuum switch that is used to turn off the cruise control when you step on the brake.
Here's a pic of my brake pedal switches. The cruise control vacuum lines go into the top of the switch on the left, so it appears that is the cruise control switch. According to my FSM, the switch on the right is the brake light switch and the white wire goes to the brake lights and the light blue wire goes to the high mount brake light:
Old Jun 12, 2014 | 02:29 AM
Hot Rod Roy's Avatar
Hot Rod Roy
What do you mean when you say "they were working"?
Did your new horns work for a short time and then quit? If they never worked, do they have two terminals, or only one? If they have two terminals, one of them must be connected to a good ground.
Just because the relay clicks doesn't prove it's good. It could still have bad contacts, which is very likely if both of your original horns quit at the same time, and both of your new horns don't work either!
Old Jun 12, 2014 | 03:11 AM
roger2000's Avatar
roger2000
wow cliff what can i say thank you so much. i'll take a look at lunchtime today and let you know. i was only looking just behind the pedal in clear site so i'll dig a little deeper upwards today. again a big thanks for your time.
Old Jun 12, 2014 | 03:21 AM
roger2000's Avatar
roger2000
thanks for the reply. i'm going to take the lot out at the weekend and start from fresh. i'll let you know the outcome. cheers roger
Old Jun 13, 2014 | 01:33 AM
Cliff Harris
You need to take off the driver's side kick panel. Several 7mm screws and there's one zip clip at the firewall. I hated that one and replaced it with a washer and a nut.
I just remembered I have a picture of the kick panel (and the screws in question):
To horn problem!!!
