spark plug question
Old Jun 20, 2014 | 08:03 PM
steve6's Avatar
steve6
Default spark plug question
soo.. I bought a 87 convertible. Runs a bit rough at idle but has had engine work (cam'd for sure, not sure of any details), not soooo bad when warm, but I can feel a mis-fire driving sometimes.
I bought 8 plugs (model according to the book), figured a good place to start. I took the plugs out of it, changed a couple and realized, wtf different length? The new ones are longer, much longer. Would this year vette ever have short plug holes as an option?? I am pretty sure that someone ****ed up, they are nice NGK platinum, but being so short just does not make sense.
https://www.dropbox.com/s/cyx0nn4y0v...2019.19.12.jpg
I tried to get a picture of how deep the hole was... You can almost see how shallow the old plug went...
https://www.dropbox.com/s/entf7kmrtv...2019.20.15.jpg
what do you guys think? Ok for the longer ones? The replacement are a champion platinum.
Old Jun 20, 2014 | 08:21 PM
captainkawasaki's Avatar
captainkawasaki
87 convertible would have had factory aluminum heads using the long thread section spark plugs. Short thread section plugs are for cast iron heads. You say there was engine work, stick a magnet on the heads and determine if iron or aluminum, then use the appropriate depth plug.
Old Jun 20, 2014 | 09:24 PM
John A. Marker's Avatar
John A. Marker
Should be aluminum heads that require longer plugs. be sure that they are actually aluminum heads and put a magnet on the head. If it sticks, the heads are cast iron and use a shorter plug. If they are aluminum then use the longer plug. The shorter plug may have an influence on your miss fire. When it is dark out, lift the hood and disconnect the lights under the hood and start the car. In the dark....look for any arcing from any of the plug wires. Wires could also be an issue.
Old Jun 20, 2014 | 10:47 PM
steve6's Avatar
steve6
I changed the plugs.. much better
Old Jun 20, 2014 | 11:01 PM
John A. Marker
Aluminum does not rust.....test head with magnet. If you went with the longer plug and the heads are cast....the plug might be too long.
Old Jun 20, 2014 | 11:04 PM
steve6's Avatar
steve6
They are aluminum, I checked with a magnet, but there really isn't many spots to actually stick a magnet too with the headers on it.
To spark plug question
