thread sealant ?
Old Jul 11, 2014 | 12:06 PM
MRPVette's Avatar
MRPVette
Default thread sealant ?
What is the best thread sealant 96 corvette exhaust manifold bolts
Old Jul 11, 2014 | 12:34 PM
John A. Marker's Avatar
John A. Marker
Don't really want to answer this question......
I would not use a sealant on manifold bolts. You should be using anti-seize on the bolt threads because the bolts are steel and your threading them into aluminum. You don't want them to seize in the aluminum. Anything else and it is a good way to set yourself up for the purchase of new heads.....
Old Jul 11, 2014 | 12:43 PM
wydopnthrtl's Avatar
wydopnthrtl
If your not having a problem don't sweat it. If you are having a problem you could do 2 things. 1. use the proper thread locker. 2. Carefully select a thread where the nut (or bolt) is just seating and deform it. This will cause an interference fit but not bugger up all the other threads on the stud/nut/bolt. Just gotta be careful to mash just enough so that the last 1/2turn or so has resistance.
Old Jul 11, 2014 | 02:51 PM
Joe C's Avatar
Joe C
I'm not aware that the factory used any kind of thread locker on exhaust manifold hardware. I would check the data sheets on the sealant to see what is the max working temperature. I would guess, that hardware might see 300 degrees or so. if there is an issue with exhaust manifold bolts or header bolts, look into locking header hardware similar to -
http://www.summitracing.com/parts/stg-8900
Old Jul 11, 2014 | 02:57 PM
GKK's Avatar
GKK
Use Anti-Seize!...
Old Jul 11, 2014 | 03:49 PM
MRPVette's Avatar
MRPVette
Anti-Seize it is thanks.
Old Jul 11, 2014 | 05:17 PM
WVZR-1's Avatar
WVZR-1
Don't get carried away with it. A "swipe" down one side of the bolt is sufficient. I know a fellow who would insist on "clean and dry" and then argue that if they intended there to be sealant of any type used or anti-seize it would be mentioned in the FSM.
I would think I'd avoid copper based product!
Old Jul 11, 2014 | 09:26 PM
MRPVette's Avatar
MRPVette
permatex? there seems to be several anyone have a part# they have used?
Old Jul 12, 2014 | 03:52 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The product I use on all steel into Al bolts is "Permatex Anti Seize"; no P/N shown on the tube. It's rather a silvery paste.
Old Jul 12, 2014 | 03:53 AM
GKK's Avatar
GKK
Here's a picture of the Permatex anti seize compound although, any brand will work.
http://s3.amazonaws.com/dpi_sp_image...3029/81343.jpg
Old Jul 12, 2014 | 07:17 AM
Paul Workman's Avatar
Paul Workman
Same can be said for the spark plugs as well. A swipe along one side of the threads is good...AND important to be there too.
Long as we're talking spark plugs and aluminum heads, removing and installing plugs should only be done with the engine cool or serious thread damage can occur. Just sayin...
To thread sealant ?
