Outer window seal problem
Old Aug 9, 2014 | 06:19 PM
snyderb's Avatar
snyderb
Navigator
Default Outer window seal problem
Hey all, have a 85 Coupe, I was replacing the outer window seal and found that the metal strip it attaches to inside the door had completely rusted out, most of it is completely gone. Does anyone know if I can replace this metal strip or am I looking at needing a new door?
Thanks for the help.
Old Aug 9, 2014 | 06:28 PM
snyderb's Avatar
snyderb
Navigator
Nothing even left to hold the rivet
Old Aug 9, 2014 | 06:59 PM
JackDidley's Avatar
JackDidley
I think I'd look for a pair of doors. Never seen anything like that.
Old Aug 9, 2014 | 10:44 PM
DinoBob's Avatar
DinoBob
Wow!
Old Aug 11, 2014 | 12:46 PM
snyderb's Avatar
snyderb
Navigator
Best I can tell it's only happened on the passenger door. What a pain. Do you know of any good places to look for a door?
Old Aug 11, 2014 | 12:48 PM
snyderb's Avatar
snyderb
Navigator
Anyone else ever see anything like this happening before. This is the only thing inside the door that has rusted, everything else is fine.
Old Aug 11, 2014 | 01:21 PM
DinoBob's Avatar
DinoBob
I am not sure a whole new door is in order. Can you fabricate a substitute and rivet it to the top of the door edge?
Old Aug 11, 2014 | 04:50 PM
snyderb's Avatar
snyderb
Navigator
Bob, I thought about that too, not sure but probably could. If I could find a really cheap door I might be able to salvage the piece from it and get it fitted in somehow. I just screwed a new outer seal in place to what was left of the old one to try and keep some water out for right now.
Old Aug 11, 2014 | 05:22 PM
corvette Stu's Avatar
corvette Stu
I'm sure you could rig something up, Contemporary Corvette in Bristol Pa. will have a used on and maybe even in your color.
Old Aug 12, 2014 | 05:27 AM
enventr's Avatar
enventr
Try to fabricate something as mentioned previously even alittle bondo and some aluminum I'm sure you can come up with something creative. Talk to your local mechanic for ideas
Old Aug 12, 2014 | 05:17 PM
snyderb's Avatar
snyderb
Navigator
Thanks much for the lead.
snyderb's Avatar
snyderb
Navigator
Thanks for the suggestion.
To Outer window seal problem
