Porting gone wrong...
Old Aug 26, 2014 | 12:27 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Originally Posted by WW7
This has to be a joke, no one could be that stupid and live past 5 years old.......WW
Old Aug 26, 2014 | 12:55 PM
bogus's Avatar
bogus
any of the old timers remember the kid who hosed Nawsssss into the valve cover of his S2000?
Old Aug 26, 2014 | 06:53 PM
ricasso's Avatar
ricasso
Originally Posted by 856SPEED
I guess every forum has their share of trolls.....
Even Audi forums.
Yep, it's not just us then..
Old Aug 27, 2014 | 11:56 AM
TA's Avatar
TA
I remember reading another one about a kid who put fluorescent paint in an engine to help him find an oil leak.
Old Aug 27, 2014 | 05:00 PM
Hot Rod Roy's Avatar
Hot Rod Roy
I actually saw a guy who jacked up his car with his jack under the rocker panel, centered on the door!! It had even wrinkled the door panel when the rocker panel caved in!! He was still trying to figure out why he couldn't pull off his front tire!!
Old Aug 28, 2014 | 05:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
Did this about a month ago. Always fun to call someone and tell them...."well we didnt strike gold but".....
Old Aug 29, 2014 | 12:14 AM
Paul Workman's Avatar
Paul Workman
AH! Well, when consulting one of out LT5 gurus prior to me embarking on some serious porting, he said: "If you don't punch through somewhere at least once, you aren't trying hard enough!
Prior to beginning such a project, it is good to know or have someone that does know how to weld aluminum runners (i.e., very tight places) before starting. There is apparently quite an art to doing it right!
For instance, I have several TIG welds that were done on my heads, mostly, and they are simply a work of art! The choice of rod is critical, apparently, and in order to gain better angle to some of the welds, the guy removed the gas shroud from the (TIG) wand and flooded the entire runner with the gas, prior to welding. I don't know if he pre-heated the (heads) prior to welding, but the resulting weld was smooth as glass; like a wet puddle. Grinding to re-shape was minimal. I wish I could tell you more about the welding, but the guy that did the work specialized on aluminum (heads) and kept a lot of his secrets pretty close to the chest.
Old Aug 29, 2014 | 10:20 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Even Audi forums.
85L98-84L83/Nelson84/12inches et al apparently lives there too.
