Newcomer needs help!
Old Aug 31, 2014 | 03:16 PM
TrevorTraffick's Avatar
TrevorTraffick
2nd Gear
Default Newcomer needs help!
I have owned my '89 C4 for just over a year now.
Had minor issues along the way (headlight motor went out, needed new distributor), but I've encountered my first big issue with the car and am at a loss.
While driving to work the other day the car began to sputter and suddenly died out in the middle of the street at an intersection. Had to have it towed home. After doing some browsing through the forum and a pressure test, I felt that the fuel pump needed to be replaced (as I read this was a common failure). Well, low and behold I've installed the new fuel pump and still nothing. No pressure at the fuel rail.
Can someone please point me in the right direction?!?!?
Old Aug 31, 2014 | 03:24 PM
ANTI VENOM's Avatar
ANTI VENOM
Can you hear the pump run for 2 sec. when you turn the key on? Fuse? I doubt your pump is running or you would have some pressure. Are you using a gauge to check pressure?
Old Aug 31, 2014 | 03:29 PM
TrevorTraffick
2nd Gear
Yes, I hear the pump run. Fuse is good, and I'm using a gauge I rented to check the pressure at the rail.
It seems like there is pressure, because when the valve stem is depressed I'm getting fuel shooting out... The gauge however still reads no pressure.
Checked the gauge with an air compressor and the gauge is fine.
Thanks for your response.
Old Aug 31, 2014 | 03:46 PM
ANTI VENOM's Avatar
ANTI VENOM
Are you sure that the gauge was screwed on good? If I remember correctly the TPI is hard to get the gauge screwed on to. If fuel is "shooting" out then you have pressure but we need to be certain before we continue the troubleshooting. Have you checked spark yet? Just curious..
Old Aug 31, 2014 | 06:33 PM
88BlueVette's Avatar
88BlueVette
7th Gear
I had similar problem. My mechanic replaced the fuel pump and did not solve the problem. The problem solved after he replaced the fuel sending unit.
To Newcomer needs help!
