C4 oil temperature control?
W'regard to the issues in this thread, RollaMo-LT4 is right. The actaul problems here is a possible oil pressure issue. steveleakeC4, you're saying that no where on your digital display, does your car show oil pressure? That can't be right... This shows OIl Pressure in the top left of the center information area...
As does this video...
84-89 Corvette Gauge Fix 1 Disassembly - YouTube
What ever the case, If that is true, then you need to acquire a mechanical gauge, and check your oil pressure so you know what it is, and if your light is erroneous. You need to know what your oil pressure is, bottom line.
The next step before pulling the motor to me are:- 1) maybe change the oil cooling from a water/oil heat exchanger to air/oil H/E; 2, fit a proper analogue gauge, as the one in the dash is only calibrated at 0 and 550 kPa, with quarters and half way point. 550 kPa is 79pisg. Maybe other way around on the order! By the way, at highway revs (1500-2000rpm) oil pressure is showing 1/4 full scale, or around 20psig.
Now you can see the importance of always listing the year of the car when asking questions.
The C4 ran from 1984 through 1996, and there were lots of changes during that time.
Also, your '95 does not have any type of factory oil cooler.
The water/oil heat exchanger your referring too was on the earlier models.
You could install an aftermarket oil cooler of your choice though.
People tell me riding my motorcycles is dangerous but I don't listen to them... As for scaring people and posting misinformation "man"... you'd have to be pretty weak sort of person to be "scared" out of driving your car as much as you want if that's what you want to do. I thought Yanks were like Aussies... I think I have just changed my opinion on that also and I will say goodbye to this forum.
Again, I'd put a mechanical gauge on it FIRST. You have to know what is going on in there. Have to.
Second, if the pressure was low, you could try a higher weight oil, since your right on the cusp of acceptable.
Last you could drop your pan and replace the crank and rod bearing shells in the car, which THAT would "extend engine life considerably".
1. You have gone and scared yourself, out of driving your own car as much as you want, so...
2. People come on here, not knowing, in search of good info. They read your post, and think that driving the 'Vette on road trips will hurt it and that is wrong. It's misinformation!
Get butt hurt and leave if you want....OR hear what I'm saying and learn something.
