Windshield Trim
Old Sep 27, 2014 | 03:11 PM
PSU69's Avatar
PSU69
Default Windshield Trim
My '86 has black metallic windshield trim which needs to be repainted. Has anyone done this? It seems to me that Rustoleum black semi-gloss might do the trick. Any thoughts? Thanks.
Old Sep 28, 2014 | 08:54 AM
jgalfo's Avatar
jgalfo
I used krylon flat black from Ace Hardware. it looks good and is easy you do if you mask it properly to avoid overspray and prep properly.
John
Old Sep 28, 2014 | 12:10 PM
PSU69's Avatar
PSU69
John
Thanks! What did you do to prep the surface?
Old Sep 28, 2014 | 10:11 PM
espop125's Avatar
espop125
Go to your local paint and body supply and get a can of SEM trim paint. That's what I used after a good cleaning and a red scotch bright pad to lightly scuff it.
Old Sep 28, 2014 | 10:17 PM
Dt86's Avatar
Dt86
I used SEM trim paint as well and was very pleased. Their products are excellent.
Old Oct 2, 2014 | 08:23 PM
PSU69's Avatar
PSU69
I used the SEM trim paint and SEM Solve and followed the instructions, including light sanding. The paint doesn't adhere very well to the bare metal parts of the trim. It looks like small bubbles.
I was wondering if I may have applied too much paint or not enough.
Can anyone offer any suggestions? Thanks.
Old Oct 2, 2014 | 09:15 PM
cormorant71's Avatar
cormorant71
I used flat black krylon. it worked great. sand the trim and apply LIGHT coats. I did 3 and no bubbles 8) if you get some use very fine sand paper between coats. easy job, just mask off everything before you do it.
Old Oct 3, 2014 | 12:36 PM
PSU69's Avatar
PSU69
Well, I went to the hardware store to try the Krylon paint. But, I saw a can of Rustoleum self-etching primer. I'll give that a shot and let you know.
Thanks for all the help. It is very much appreciated.
Old Oct 3, 2014 | 03:09 PM
Dt86's Avatar
Dt86
I would guess that there was still wax or grease on the trim. Not saying it wasnt prepped right but from your description of the paint lifting it sounds like an adhesion issue.
Old Oct 3, 2014 | 03:16 PM
PSU69's Avatar
PSU69
I agree. I thought the Solve would clean everything up. The Rustoleum primer seems to be adhering pretty well. I have to wait a few hours to repaint.
Old Oct 3, 2014 | 07:17 PM
PSU69's Avatar
PSU69
It looks like the primer worked,and the trim paint adheres pretty well and looks good. Thanks again, everybody.
To Windshield Trim
