Bose amp problem?
Old Oct 21, 2014 | 11:08 PM
lectroglide's Avatar
lectroglide
Default Bose amp problem?
From all I read its possible the left front bose Amp is shot, when turning on the radio am hearing hissing noise on the drivers side, the sounds are coming out from the other 3 speakers but cant really hear drivers side, guess Im wanting to know and confirm the left amp is shot before I send it in.
Old Oct 22, 2014 | 11:28 AM
corvettenorway's Avatar
corvettenorway
http://www.carstereoremoval.com/htm/...lChevrolet.htm
Old Oct 22, 2014 | 12:18 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
fill out your profile so it's easier to figure out what car you have
Old Oct 22, 2014 | 03:50 PM
deptcruser's Avatar
deptcruser
Default Bose Amp
I have the same problem plus a blown amp in rear. Decided to change out the radio and speakers. If your interested I'll sell you the right side amp for $40 shipped. That's half the cost of a rebuild. Mine is a 94 coupe with the bose gold system.
Old Oct 22, 2014 | 04:04 PM
Richard Raichert's Avatar
Richard Raichert
Default Join the club!
Common problem with Bose. Mine is a 94 Bose gold, I had to have both rear amps rebuilt/updated. They hiss or do nothing! A source for rebuild is below. If a newer C4 the amps plug in and it is easy to remove and send just the amp rather than the whole speaker. See the site for easy speaker removal. Mine cost $80 each to upgrade, quick turnaround.
www.carstereohelp.com
P.S. 99% of the time it's the amp not the speaker
Old Oct 22, 2014 | 04:07 PM
lectroglide
[QUOTE=deptcruser;1588098776]I have the same problem plus a blown amp in rear. Decided to change out the radio and speakers. If your interested I'll sell you the right side amp for $40 shipped. That's half the cost of a rebuild. Mine is a 94 coupe with the bose gold system.[/QUOTE
PM sent
Old Oct 22, 2014 | 04:14 PM
deptcruser's Avatar
deptcruser
your mailbox is full
Old Oct 22, 2014 | 06:01 PM
lectroglide
ok check it now
Old Oct 22, 2014 | 06:14 PM
lectroglide
do my car pictures not tell you enuff or do ya need more
Old Oct 22, 2014 | 07:40 PM
summerst's Avatar
summerst
Best way to confirm is to pull both front speakers and switch them.
Old Oct 22, 2014 | 09:51 PM
Cruisinfanatic
do you really expect someone trying to help you to have to dig through your old posts to figure out what you have?
Old Oct 25, 2014 | 10:28 AM
pcolt94's Avatar
pcolt94
I do agree first step with a problem like yours is the switch the speaker amp boxes for test and make sure what the problem is. Most of the links and information is for amps making weird sounds and replacing capacitors usually fixes the problems. However with no sound it could be the speaker amp or the CDM and before sending anything in you need to determine what box is bad.
Radio configurations vary greatly across the C4 line of cars. Put your year of car at least in your posts and you will get more help. Without the year there is a lot of guessing going on. If I knew the year, I might recommend a specific part to look at.
This is my link for repairs on the speaker amps I have done last 8 years or so. But if it is the CDM you will probably need to send it in.
https://www.corvetteforum.com/forums...-and-more.html
Old Oct 26, 2014 | 09:16 AM
fl_799's Avatar
fl_799
For a DIY solution:
Pull the speaker boxes, remove the amps and replace all of the Radial electrolytic caps on the circuit board with like values. Mouser, Digikey, or Allied electronics will have what you need. $5 per amp in caps and an hour of labor will get it done.
Old Oct 27, 2014 | 02:49 PM
lectroglide
Quote{ Radio configurations vary greatly across the C4 line of cars. Put your year of car at least in your posts and you will get more help.
am surprised no one can tell what yr I have by just clicking on the vette pictures, but being new to this forum I could be wrong, and I certainly didn't know info varied re C4 boze systems, anyway thanx to one of the members on here I have a new speaker amp coming.
Old Oct 27, 2014 | 04:06 PM
Cruisinfanatic
am surprised no one can tell what yr I have by just clicking on the vette pictures, but being new to this forum I could be wrong, and I certainly didn't know info varied re C4 boze systems anyway thanx to one of the members on here I have a new speaker amp coming.
what vette pictures?
Old Oct 27, 2014 | 09:25 PM
lectroglide
all ya gotta do is look at>>>>>>>>>>> MY CORVETTE PHOTOS
Old Oct 27, 2014 | 09:28 PM
lectroglide
Just installed the new amp board and sounds like a million bux! but was a PITA putting it back in but worth the effort, As you can see something got fried it also smells burnt........................o
Old Oct 28, 2014 | 07:26 AM
pcolt94's Avatar
pcolt94
Just installed the new amp and sounds like a million bux! only difficult part was putting it back in but worth the effort, As you can see something got fried on the board it also smells burnt........................o
Nice. That board is in rough shape. Probably a new board was a smart answer for this one. Not a common problem.
To Bose amp problem?
