95 vette
Old Oct 27, 2014 | 10:09 PM
firsttimechevy's Avatar
firsttimechevy
Default 95 vette
I. Reacntly bought a 95 vette with lt1 would a bigger throttle body make a difference with an slp air induction
Old Oct 27, 2014 | 10:27 PM
Silver96ce's Avatar
Silver96ce
No.
Old Oct 27, 2014 | 10:43 PM
John A. Marker's Avatar
John A. Marker
you will find no change by going to a bigger TB. They are not like putting on a bigger carb. For a stock engine you are just fine with what you have.
Old Oct 27, 2014 | 10:59 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
More in without the ability to get more out =0, You would also need to add tune, heads, injectors, headers & exhaust. HP is addictive and $.
Old Oct 28, 2014 | 03:51 PM
firsttimechevy
Default 95 vette
How can I get more power out of my lt1 it has only 61000 miles
Old Oct 28, 2014 | 04:22 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Most add headers and exhaust first as they are simple upgrades they will give you a true 20hp+ gain. Another bang for the buck are rear gears they will not add HP but a seat of the pants gain at the low end. After that its all dependent on your $$$$$.
Old Oct 28, 2014 | 04:25 PM
corvette Stu's Avatar
corvette Stu
Drain you Bank Account
Old Oct 28, 2014 | 04:39 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
This question always reminds me of a sign posted in a Speed Shop back in the 70's
Speed costs money
How fast you wanna go?
Old Oct 28, 2014 | 04:44 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The exhaust system is the first place most owners go, but that is really just the first step. The exhaust (headers, pipes) won't give you any real power increase (by themselves), but freeing up the exhaust enables the next steps (cam, heads, etc.) to do the job they can do. Adding horsepower is a system, with the total greater than the sum of its parts.
It's a series of building blocks, each mod building on the ones before it AND the ones after it.
Aftermarket power: figure on spending about $50 total for every one horsepower you increase. Want another 100hp? Plan on writing a $5000 check.
(this includes professional installation and/or replacing broken parts, in the case of nitrous)
Old Oct 28, 2014 | 05:44 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
I do agree with almost everything you say but whats in red, although not an LT1 headers and freeflowing exhaust/with cats added 20+ rwhp to mine. I started with 324rwhp and went to 349rwhp.
Old Oct 29, 2014 | 06:27 AM
corvette Stu
I got the time slips to prove it. If I can find them in all the mess in my garage.
Old Oct 29, 2014 | 10:04 AM
lt4obsesses's Avatar
lt4obsesses
http://home.insightbb.com/~nathan.pl...rformance.html
I've found this to be about the most comprehensive and straight forward info on the topic of the LT1.
In the years that I have been on here, the one thing I have read is that the stock TB can handle just about anything you throw at it until you start adding cubic inches to the cylinders, even then it depends on your cam and heads.
What folks seem to agree on for the LT1 is long tube headers, 1.6 rockers and springs, and rear end gears. These seem to give the most bang for buck without cracking open the engine.
Old Nov 16, 2014 | 05:18 PM
firsttimechevy
Default 95 vette
would a hypertech programmer work
Old Nov 16, 2014 | 07:30 PM
Silver96ce's Avatar
Silver96ce
The hypertech is good for altering speedo calibration if you change the rear gears, changing shift points in auto trans and I think the rev limiter in your year. On a '96 you can change the fans turn on and off temps - IDK if you can do that on yours. Otherwise, to my knowledge, you won't get any more engine power from it.
To 95 vette
