Ignition key
Old Oct 29, 2014 | 09:13 AM
tbirdsps's Avatar
tbirdsps
Default Ignition key
The key mechanism has started to not let go of the key. It takes a little wiggling to remove the key. Will cleaning/dry lube fix it or is it now toast and needs replacement?
Old Oct 29, 2014 | 09:43 AM
WVZR-1's Avatar
WVZR-1
An attempt at the clean and lube is the only way to actually confirm. Be sure to use appropriate lock cylinder lube and you mentioned "dry" so I believe you understand. You didn't mention year so you might mention that. It looks like your car is a '90 or earlier and there's differences in the M6 column vs. the 4+ and the A4 columns regarding key release.
Old Oct 29, 2014 | 10:46 AM
tbirdsps's Avatar
tbirdsps
Yup, 1990. How to clean? Electronics spray let dry then lock cylinder lube?
Old Oct 29, 2014 | 11:03 AM
WVZR-1's Avatar
WVZR-1
M6 or A4? Yes contact cleaner and the real graphite/dry lube for lock cylinders. You said "doesn't let go of key". What do you mean? Cylinder doesn't rotate all the way back to lock OR...
I would guess you could use a hair blow-dryer to force the dry of the cylinder. What is the quality of your key? Do you have spares? A new key with really sharp cuts can hang in a cylinder also. If the key is new drag an emery board/nail file across the key cuts briefly on all three sides of the cuts.
Old Oct 29, 2014 | 01:35 PM
tbirdsps's Avatar
tbirdsps
It rotates to all positions. It's hard to pull the key out without jiggling a bit, it just started this last Saturday. I don't drive it everyday. I haven't tried the spare but all the keys are original to the car.
Old Oct 30, 2014 | 09:31 AM
tbirdsps's Avatar
tbirdsps
Default I feel like a dumbass
When I tried the spare key, no problem. It was then I noticed the slight bend in the key I was having problems with.
Old Nov 1, 2014 | 02:18 AM
BadUmp's Avatar
BadUmp
don't sweat it...
when I first got mine I was having trouble getting the key out as well.
about every other ride I had to leave the key in the car.
finally called the local vette shop and the mechanic told me:
"just pull the shifter back a touch"
who'd a thunk ?
To Ignition key
