84 wheels
Old Oct 30, 2014 | 12:55 PM
7thone's Avatar
7thone
8th Gear
Default 84 wheels
Walking around a car show here in Vegas and met a Lady who was there with her 84'. She was very proud and was telling me all about it. After I saw it I had to tell her that #1] The wheels were on wrong and #2] They are different width's if you have the optional sport suspension...10" in rear and 9" up front. 3]Directional Tires. She left to go to the tire store and get those fixed pronto.
Old Oct 30, 2014 | 01:21 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Without seeing a picture, how are we to know if they were on wrong or not?
Many people "assume" they are on backwards, when in fact they are on correctly for that model year.
The early C4 wheels would look backwards to most people familiar with only seeing later model C4's.
Oh, and the '84 Corvette never had 10" or even 9" wheel widths from the factory.
Old Oct 30, 2014 | 01:44 PM
Z51JEFF's Avatar
Z51JEFF
84s had 16-8.5 in the front and 16-9.5s in the rear if it had the Z51 option,if not 16-8.5 front-rear.
Old Oct 30, 2014 | 01:54 PM
Hot Rod Roy's Avatar
Hot Rod Roy
7thone, what do you call "correct"? Were the blades at the top of the wheel swept forward, like a circular saw blade, or were they swept backward, like a shark dorsal fin?
I have a copy of the original '84 Factory Specifications. It shows the standard wheels as 16" x 8 1/2", front and rear, and the optional Z51 wheels as 16" x 8 1/2" front and 9 1/2" rear. The original "standard" wheels were to be 15", but no '84's were fitted with these 15" wheels.
I have 16" x 9 1/2" on my '84, f & r.
Old Oct 30, 2014 | 02:47 PM
7thone's Avatar
7thone
8th Gear
Yes they did...Different front and rear...Mine are bigger in the rear..9.5 versus 8.5 front...Never say never!
Old Oct 30, 2014 | 02:51 PM
7thone's Avatar
7thone
8th Gear
Optional SPORT suspension, optional cloth interior w/lumbar seats...Maybe you just have the PLAIN or cheapie Vette... Mine has 8.5 front and 9.5 rear...Blade tilts to the front ...Hence nickname "SAWBLADE"...far too many know it alls here!
Old Oct 30, 2014 | 02:56 PM
7thone's Avatar
7thone
8th Gear
Mine are 8.5 front and 9.5 rear.I measured them when they put on new tires.
Old Oct 30, 2014 | 03:12 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
...10" in rear and 9" up front..
I think this is what were the disagreement come in. 8.5 and 9.5 not what you stated. the size is cast into the backside of the wheels
Old Oct 30, 2014 | 03:18 PM
don hall's Avatar
don hall
'84 wheels:
http://www.joby.se/corvette/div/corvette_wheels/
Old Oct 30, 2014 | 04:07 PM
RollaMo-LT4
I didn't say that different front and rear sizes were not possible.
I said they were not 10" wide or even 9" wide.
Go back and read what you wrote in your original post.
10" Rear, 9" Front.
....far too many know it alls here!
Yeah, good luck with your attitude.
Your very first post, and you start questioning people that "might" know a little about these cars.
Old Oct 30, 2014 | 04:46 PM
7thone's Avatar
7thone
8th Gear
Key word is "MIGHT"....Not my first post..Been on and off this site for 9 years...I usually get off when I read replies from OUTHOUSE lawyer's who pick apart everything the guy state's...Your right I did say 9&10..Should have stated that they are 8.5 - 9.5....1/2 inch is measurable on the outside on the car...Measure center depth with straight edge...Someone stated that only z51 had those they are wrong...Mine does and its not a z51...Don't know where or who did it but there they are.
Old Oct 30, 2014 | 04:50 PM
7thone's Avatar
7thone
8th Gear
No if you measure to the center of the CAP with a straight edge it's .5 outside and .5 inside.When I get film I will prove it to you. take care
Old Oct 30, 2014 | 04:53 PM
7thone's Avatar
7thone
8th Gear
Never said they were from the FACTORY..Don't know how they got on the car, but they are there. First time I changed tires was about 3 yrs ago and I found it then, and Ive had the car 6 yrs.
Old Oct 30, 2014 | 04:57 PM
RollaMo-LT4
This thread is your first posts under this user name.
So, what names were you using before?
Well, you've proven you don't know how to measure wheels.
Old Oct 30, 2014 | 05:09 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Here is all you need as to the wheel size GM offered on the 84..
http://www.corvetteactioncenter.com/...4/84specs.html
If you would have looked at this post you would have know also.
Originally Posted by seabright
Old Oct 30, 2014 | 05:43 PM
whalepirot's Avatar
whalepirot
Some 'tudes on this thread are why i left long ago, only recently returned.
I suggest not replying to know-it-alls; let them live in their ignorant state. After all, they already know it all! when you argue with fools, you're lowered to their level, after all.
My stock sawblades were drilled off center which made balancing them an oft-repeated exercise. Gracias Chevrolet.
Old Oct 30, 2014 | 05:51 PM
WVZR-1's Avatar
WVZR-1
"THE LADY" may very well be having the "LAST LAUGH" and I certainly hope so! If they actually removed a wheel and confirmed the correct rotation for her she may be on the lookout for you to put a foot in your a$$.
To 84 wheels
Old Oct 30, 2014 | 10:15 PM
Hot Rod Roy
Originally Posted by whalepirot
I suggest not replying to know-it-alls; let them live in their ignorant state. After all, they already know it all! when you aregue with fools, you're lowered to their level, after all.
FYI These wheels are marked on the inside with the size and the correct direction of rotation. Any good tire guy will see this info. End of argument!!
Old Oct 30, 2014 | 11:59 PM
Frizlefrak's Avatar
Frizlefrak
Yep
They are marked left and right on the inside of the rim. The 84 blades point forward.
Old Oct 31, 2014 | 03:51 AM
Cliff Harris's Avatar
Cliff Harris
I have heard that the vanes in '84 wheels are "backwards" compared to the later years. The owner of an '84 told me that.
