Electrical issue
Old Nov 13, 2014 | 05:24 PM
videoprojeff's Avatar
videoprojeff
Default Electrical issue
Hello all,
I have an issue that cropped up on my '94 last week. I noticed alternator whine in the speakers, and fluctuations in the LCD portion of my dash. My first thought was that the alternator is on its way out. I verified its output and it seems to be right on.
Yesterday I decided to do some troubleshooting, thinking it might be related to the tuner in the storage compartment. After some tinkering with that, I checked the speakers again, and the whine was gone. Yay! No! Today when I fired up to go to work, the whine was back, and when I turned the stereo off and back on, the LCD blinked off then back on. I also noticed that when raising the passenger window, I heard some popping in the right speaker near the top of the window's travel. Back to square one! Any thoughts out there?
I recently replaced the passenger window guide, but the hum did not appear for a few weeks. I also cleaned out the storage bin. It had collected some water, but the tuner was not wet.
Old Nov 16, 2014 | 06:33 AM
Paul Workman's Avatar
Paul Workman
It has the earmarks of a grounding issue. Do you have a FSM? That would be a place to start; see what ground connections are common with those systems that seem to be related...is a good place to start.
Good luck!
Old Nov 16, 2014 | 12:34 PM
videoprojeff
Default Fixed!!
Good luck!
It was the alternator itself as it turned out! My mechanic gave me a couple of tricks to try in troubleshooting, and it was the alternator. Fixed 'er up and all is good now. No more electrical gremlins. Thanks for the input!
Old Nov 16, 2014 | 05:03 PM
mlm0's Avatar
mlm0
What were the tricks ?
Old Nov 17, 2014 | 02:16 AM
Cliff Harris's Avatar
Cliff Harris
One trick is to disconnect the alternator and drive without it. I have driven about 20 miles on a blown alternator, so it's definitely possible.
To Electrical issue
