Rear Diff Question
Old Dec 11, 2014 | 04:01 PM
smdorsey's Avatar
smdorsey
Default Rear Diff Question
Wanting to swap out the 2.59's and found a Dana 36 3.07 rear differential and batwing for cheap. Donor car is a 1995 with 116,000 miles. What say you CFGD? Does the mileage scare you?
Stay Frosty!
Stephen
Old Dec 12, 2014 | 07:06 AM
WVZR-1's Avatar
WVZR-1
Stay Frosty!
Stephen
You mentioned "cheap" so I'd just go ahead and do the six bearings and three seals required to refresh it. The D36 clutch pack is I believe pretty pricey but not knowing what "cheap" is then maybe there's room for it also. You need to check the 2 pinion washers and the pin in the differential and maybe do those washers anyway as part of the "refresh"!
I don't know that there's a particular reason to be concerned about the miles but I'd seize the opportunity to check it very close. If it's severely grimed up maybe it's had leaking seals, a quick lance should confirm this if it's an issue.
CHEAP isn't always a "bargain"!
A simple calibration in the PCM corrects the speedometer/odometer issue.
Old Dec 13, 2014 | 05:18 PM
Klondike's Avatar
Klondike
If it needs those little axle shafts replaced, the cost goes up!
Before you take it, check the end play on both sides. Grab the U-joint flange and give them a push/pull wiggle to see if there is any slack. I think the Max allowable is about .004" so you shouldn't be able to slide them in and out hardly at all. If either one or both slide 1/8th of an inch or more, the shafts are worn and could have shed iron dust into the rest of the moving parts as well.
I couldn't figure out why only one shaft was worn on mine till I put new tires on and the guy at the tire dealer showed me the Rt side wheel had a slight wobble. It was causing the axle to beat against the cross shaft and wore the end down past the wear limit.
Old Dec 14, 2014 | 08:56 PM
THE 383 admiral's Avatar
THE 383 admiral
check the clutch pack resistance. Lift 1 wheel, The Dana 44
should not slip 70lbs or less. Dana 36 should be similar.
Old Dec 14, 2014 | 11:41 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Take it to a diffential shop and get it rebuilt. This will eliminate any surprises. It could be in the$400-$600 range, but it will be worth it. I did this to my 95 about a year ago. They reused only the gears, all other parts are new.
Old Dec 15, 2014 | 01:02 PM
aklim's Avatar
aklim
Or get a D44 rear end, batwing and C-beam and rebuild that sucker
Old Dec 18, 2014 | 10:14 PM
kkperformance's Avatar
kkperformance
Default dana 36
The 116xxx miles dont scare me at all. have it checked, BTW i have a used 3.08 form a dana 36 and a NEW richmond 3.54 with install kit if your interested.
Old Dec 19, 2014 | 04:18 PM
smdorsey's Avatar
smdorsey
PM Sent.
To Rear Diff Question
