radio
Old Dec 28, 2014 | 12:53 PM
rat123's Avatar
rat123
Default radio
Hi
Is there a adaptor that the original harness(Black, blue, white plugs) for radio plugs in and the other end plugs into the radio to give me more wire. Male to female. I know I can extend them manually by adding wire to each wire. For a 1984 corvette radio with bose speakers
thanks
Old Dec 28, 2014 | 01:21 PM
DinoBob's Avatar
DinoBob
Probably not unless you make it. While these wires are very short, it is possible to connect them. I always put the key in, and shift the car into low while connecting the radio, to get the shifter out ofvthe way, and put a cloth down on the console to keep from beating it up. I have had my radio out/in three times while adding an iPod interface and aligning the cassette head. It is a pain but can be done.
Old Dec 28, 2014 | 05:49 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Originally Posted by rat123
Hi
thanks
why is it you want to do that? Problem is if you do, it's difficult to get all that wire back up in to reinstall the radio
Old Dec 29, 2014 | 01:49 AM
Dt86's Avatar
Dt86
Ain't that the truth. Try it after stuffing a double din in there! I cringe thinking about having to do that again...
To radio
