1992 inside door panel help
Old Dec 28, 2014 | 03:34 PM
reg_255's Avatar
reg_255
Default 1992 inside door panel help
Hello All,
As a lot of others, my door panels do not stay in place.
Is it because the tabs on the inside fiber glass panel are broken?
Is there some kinda of fix for the broken tabs?
Can that inside panel be replaced?
All constructive advice is appreciated.
Thanks,
Roy
Old Dec 28, 2014 | 05:20 PM
captboatwrench's Avatar
captboatwrench
there are plastic inserts that fit into slots in the fiberglass where the door panel screws go into. and they are replaceable
Old Dec 28, 2014 | 05:36 PM
MRPVette's Avatar
MRPVette
I fixed mine a while back there is a thread on here somewhere using L brackets from homedepot or lowes.
Old Dec 28, 2014 | 06:50 PM
reg_255's Avatar
reg_255
Thanks all for the replies.
MRPVette,
I've been searching the forum for your fix unsuccessfully.
I did come across this, was wondering if this is what you did?
https://www.corvetteforum.com/forums...re-ties-3.html
Old Dec 28, 2014 | 06:54 PM
yaknow's Avatar
yaknow
To 1992 inside door panel help
