Need help.
Old Jan 5, 2015 | 12:12 PM
RGM94's Avatar
RGM94
8th Gear
Default Need help.
My 1984 corvette had a leaking fuel Injector I replaced the gaskets on It and now everythings fine but then I found a ripped spark plug wire went to replace It and turned the car on and Im getting a loud popping noise. It's gas and its super strong the car will stay on but continues to pop anyone know what could be wrong? I replaced the fuel filter yesterday as well.
Old Jan 5, 2015 | 09:54 PM
ex-x-fire's Avatar
ex-x-fire
A loose or broken spark plug?
Old Jan 5, 2015 | 10:06 PM
RGM94's Avatar
RGM94
8th Gear
I just replaced all the spark plugs so that couldn't be it, If I only replace one spark plug wire should I do all of them? Do you think to much power is going to that one and not the others?
Old Jan 6, 2015 | 05:46 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Originally Posted by RGM94
I just replaced all the spark plugs so that couldn't be it, Do you think too much power is going to that one and not the others?
If you just replaced the spark plugs, that's the first place to look. There's probably something wrong there. Maybe a loose or broken plug wire. Start the engine at night, when it's dark, and look for visible arcing in any of the wires. Did you check the gap of each spark plug before you installed it? Did you have trouble installing any of the plugs?
There is no such thing as "too much power" going to one spark plug!
Old Jan 6, 2015 | 06:18 PM
frankinvett84's Avatar
frankinvett84
I have crossed plug wires in past and have had similar results. hope its something easy like that.
Old Jan 6, 2015 | 06:29 PM
RGM94's Avatar
RGM94
8th Gear
I made sure the wires weren't crossed yesterday so thats out of the way, and the spark plugs are gapped correctly and none are broken. I really don't know what It could be then. I don't have alot of gas In the car you think maybe If I go get about a half a tanks worth maybe It'll start and the popping will go away?
Old Jan 6, 2015 | 06:32 PM
RGM94's Avatar
RGM94
8th Gear
Btw thanks for the help guys really appreciate It I hate seeing It just sit there day after day.
Old Jan 6, 2015 | 07:05 PM
DinoBob's Avatar
DinoBob
My money is on a loose or badly cross threaded spark plug.
Old Jan 6, 2015 | 07:06 PM
DinoBob's Avatar
DinoBob
Also, if you had a leaking injector, change the oil and filter now. Trust me just do it.
Old Jan 6, 2015 | 07:36 PM
RGM94's Avatar
RGM94
8th Gear
Alright It's not gonna be the spark plugs but Im gonna do the oil and filter. I'll get back to you
Old Jan 7, 2015 | 02:15 AM
Hot Rod Roy
So you refuse to listen to any of us about checking the spark plugs??
Old Jan 7, 2015 | 02:17 AM
RGM94's Avatar
RGM94
8th Gear
I'll double check them In the morning.
Old Jan 7, 2015 | 10:25 AM
MaxDaemon's Avatar
MaxDaemon
Soo .. you've replaced an o-ring in a fuel injector, all the plugs, one plug wire. For troubleshooting, you've checked to make sure none of the wires were put back on the wrong plugs, and made sure the porcelain is intact on all the plugs and that none of them were installed incorrectly. You've also replaced the fuel filter.
Is the noise more of a pop like a cork, or an arc like an electrical short?
You said "it's gas and it's super strong" - do you mean there's gasoline all over the top of your engine and you can smell it? Has that gas evaporated by now, or is it still being added to?
Old Jan 7, 2015 | 02:01 PM
ghoastrider1's Avatar
ghoastrider1
A loose plug, even one about to fall out, will make a huge popping noise, regular as a heartbeat. check them.
Old Jan 7, 2015 | 02:30 PM
RGM94's Avatar
RGM94
8th Gear
No the gas is super strong from the mufflers and I just changed the oil and oil filter. Now It has a really rough idle and sounds like theres too much air Instead of fuel. And I double check the spark plugs and wires and there all fine. The popping from the mufflers goes away after about 30 seconds and black chunks of stuff is coming out of the mufflers when it pops.
Old Jan 7, 2015 | 02:31 PM
RGM94's Avatar
RGM94
8th Gear
Changed them now It idles and theres still a loud popping from the mufflers. And the engine is super loud like theres too much air instead of fuel.
Old Jan 7, 2015 | 09:21 PM
MaxDaemon's Avatar
MaxDaemon
Maybe the formerly leaky injector is now dumping fuel into the system - making it backfire?
I dunno. Just random thoughts...
To Need help.
