96 LT4 engine temp questions
Old Jan 5, 2015 | 11:28 PM
kevinpepsimech's Avatar
kevinpepsimech
Default 96 LT4 engine temp questions
Ive had this car about 4 months now, at first it overheated- dealer replaced the radiator and cap which worked for a month until the heads blew- had a complete head job done- runs well but when im idling the temp goes as high as 211- 215- when Im driving it sits at 205 all day long,is this normal for these cars- fans are working, has good anti freeze and level good- I did try and squeeze the top radiator hose to see if I could feel a surge back to check the water pump but couldnt really tell a difference- I also smell anti freeze at times and noticed my heat really doesnt work ( any connection to temp) any ideas? Thank you.
Old Jan 5, 2015 | 11:30 PM
MaxDaemon's Avatar
MaxDaemon
https://www.corvetteforum.com/forums...peratures.html
Old Jan 6, 2015 | 12:46 AM
Klondike's Avatar
Klondike
If you are seeing 205* as a steady temp while cruising, you are in GOOD SHAPE & OK. My LT4 stays between 200* & 209* on a Texas summer day ride on the interstate. If your fans pop on around 227* they are working OK too. When I first got my car I thought the engine temps were too high too, but I learned that the LT engines were designed to run hotter. I also learned that when stuck in slow moving traffic when the temps start to rise, turn on the A/C. It turns on both fans and the engine cools right down.
Just try not to idle in traffic for an hour with the A/C on High like I did once, because at Idle the alternator can't keep up with the battery drain for that long. I was watching my temp gauge and not my voltage and it dropped to about 10v before I noticed and sped up my idle speed. Didn't hurt anything but you could have cooked a steak on that alternator..it got HOT!
Old Jan 6, 2015 | 09:22 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Do some searching around here, and you'll find enough posts on this subject to keep you busy for days.
If you have the proper coolant mix and pressure cap, your coolant won't "Boil" until over 260°F
Your cooling fans will run at a slower speed when they first come on, and then move to a higher speed as the temps reaches approx. 228°F (based on the reading from the digital gauge).
While sitting in stop and go traffic: 217°F - 235°F
Moving at any speed over approx. 40 mph: 190°F - 200°
Here are a few to get you started:
https://www.corvetteforum.com/forums...lant-temp.html
https://www.corvetteforum.com/forums...s-too-hot.html
https://www.corvetteforum.com/forums...ioning-on.html
https://www.corvetteforum.com/forums...ating-but.html
https://www.corvetteforum.com/forums...-question.html
https://www.corvetteforum.com/forums...r-heating.html
https://www.corvetteforum.com/forums...-too-high.html
Old Jan 7, 2015 | 01:07 AM
Lk12's Avatar
Lk12
I bought a 96' that supposedly needed a head gasket. Turned out that it was the spline drive coming out of the front cover and the coupling. It was stripped out so it was barely turning the pump, making it overheat. I went with the Meizeire pump option.
Old Jan 10, 2015 | 01:12 PM
mtwoolford's Avatar
mtwoolford
Thanks for that nugget of information
Old Jan 10, 2015 | 02:51 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Feb 13, 2015 | 07:30 AM
NoTyme's Avatar
NoTyme
[/QUOTE]
Ouch!
Old Feb 13, 2015 | 08:28 AM
kg4fku's Avatar
kg4fku
36 years?
Originally Posted by PLRX
To 96 LT4 engine temp questions
