Automatic transmition consensus
"I suggest smoothing the sharp edges of the valves with emery cloth so they move more easily. They tend to bind in the valve body otherwise. That's why they are so hard to get out. "
People come to these sites to get help on problems with their car. Often, they are trying to save some hard earned money. Giving false information loosely does a disservice to these people and can cause hundreds of more dollars in damage.
Personally, I'd probably ask you and Cliff why you hold your particular opinions.
Or actually, I'd probably not. As me doing work on my own transmission is a less than zero sum possibility.
The kits vary is why I was so vague on exactly what it does after installing it.
For example. When I put one in my 4l60e transmission in my gmc pickup I was out to fix a problem with it slamming into 2nd gear when you drove it more than 6 miles or so at 50 miles an hour or faster and came to a stop and the went to take off again. The violent shift was horrible. Literally would make your head bounce off the back glass of the truck. GM made a fortune selling rebuilt transmissions to customers that didn't know any better to the tune of $2500 plus labor. Nice racket. The part to fix this cost $9 for a valve in the valve body.
So to fix it I bought a shift kit made by transgo. This kit came with the valve I needed plus other parts that would make it very hard to downshift while driving. 4l60e's loved downshifting from overdrive if they even smell a hill coming up. Also it came with stronger springs that made the shifts firmer and a few fixes for known wear problems.
All of this was in a $50 or so shift kit. Came in a small card board box.
You drop the pain on the trans and remove the old filter. Then remove some bolts from the valve body and remove it from the transmission. Place it on a work bench and install the "kit" you bought into the valve body. I think the valve I bought for the tcc sticking (2nd shift issue I first mentioned) went into the pump housing edge but in general all of the parts went into the valve body. After you complete the modifications to the valve body its re-installed back onto the trans.
Then you put a new filter on and bolt the pan back on. Fill the trans and your done.
So its a bit more than just changing the fluid and filter but nothing like actually removing the entire transmission and rebuilding it.
And apparently Cliff had some specific instance where he found smoothing off those edges made something work better for him.
<backs away slowly from the discussion>
The kit also stops the converter from partially engaging. So its either on and off not a percentage of duty cycle. This REALLY helps. It lowers trans heat, extends converter life and helps the fluid do better longer.
I did a search on your "Sharp edges on valve body valves" and got a LOT fewer hits when I added 700r4. I found this link (see the last post in the thread) for somebody else who fixed his trans by filing a valve:
http://forums.superchevy.com/super-c...#__federated=1
Since you provided two links, let me do the same, in the interest of busting Internet myths that have been repeated forever:
http://www.misterpeachy.com/VetteStu...th_Busted.html
http://www.misterpeachy.com/VetteStu...elay_Myth.html
I made a statement of what worked for me. That's all it was.
Did some posts in this thread get deleted? I went back through it and some of the ones referred to seem to be missing (like the two links, which I could not find).
Am glad you have thick skin, we all learn to cope with the thoughtless and out of context comments from valued information shared on this forum.
(Re me mentioning the wide open throttle shift inhibitor to overdrive, i will be making sure my new transmission will have that modification) My 85 corvette is not standard, the transmission not shifting into overdrive during a airport runway timed competition event was a major hindrance.
I value your many years of in depth knowledge shared on this forum, Your willingness to help and your many years of membership proves you know what you are talking about.
We are all continually learning about every aspect of our Corvettes, perhaps a lot do not think or read the whole thread before they post comments.
We forum members have no right to assassinate someones character in public, perhaps a private message asking to clarify a comment will help us all feel better. Some do like nothing better than to argue a point, why...
"1992 Corvette 4L60/700R4 Valve Body Rebuild" you specifically stated and I quote,
"I suggest smoothing the sharp edges of the valves with emery cloth so they move more easily."
In that thread, I pointed out to you that the sharp edges were there for a reason. You asked me where I got that information and I supplied you with two links. One of them was from Sonnax which provided a fair bit of information. Are you now trying to suggest to the masses that a company like Sonnax is spreading internet myths? If people choose to believe that their information(and any other company in the hydraulic industry) is wrong and yours is gospel, them so be it.
In the interest of full disclosure here, I did do a little research and found arbee's references. The sharp edge is there to act as a wiper, because the small clearances inside the valve body, along with the actual valve environment, dictate that design. We're talking tolerances in the tens of thousands of an inch.
Cliff's corrective action worked for him and that's good. A tiny bit of wear could feasibly be corrected with emery cloth. Emery cloth doesn't remove a whole lot of material.
I've taken apart several trannys over my car mechanic career back in the 80s but I don't call myself an expert. I know enough to get in trouble, then out of trouble most of the time. All the trannys I put back together worked with no comebacks, if that says anything.
Bottom line in my opinion is that both of you are correct. Arbee is right about the design, and Cliff is right that what he did corrected the problem in his tranny. I say we all drive to someplace warm and have a cold beer.
From James Halderman, member of the SAE and author of several automotive books
http://www.google.ca/url?sa=t&rct=j&...84349003,d.cGU
Go to page 111 of this link and read the part in bold
http://www.hotrodlane.cc/New%20HEMI%...mi%20trans.pdf
From a book entitled: Light and Heavy Vehicle Technology by MJ Nunney
https://books.google.ca/books?id=Xnw...0edges&f=false
Drive Line publication from Joseph Industries
http://www.joseph.com/pdf/trans_dl.pdf
I have no idea why it is that apparently a bit of emery cloth was a fix for Cliff. I suspect that with some wear, the sharp edges might be a detriment and might cause binding that would be alleviated by smoothing. Or that might be completely off base.
In the end, I don't really care. You've made your case. Can we move on?
